MOGolf
- Joined
- Jun 27, 2001
- Location
- underneath something
- TDI
- 2001 Golf GLS TDI Reflex silver, rough road suspension and steel skid plate, 2004 Passat Variant, Candy White, rough road suspension and geared balanced shaft module, and much, much more. 2016 LR RR HSE TD6, 2019 Jaguar I-PACE
Based on the Bentley CD but includes other groups not documented there. Actual labels/values displayed may vary.
Group 000 measuring blocks
From left to right
Engine idle speed: range 42 - 45 = 870-950
Start of injection: range 12 - 75 = 2 degrees ATDC - 3 degress BTDC
Throttle position: 0 = 0 %
Injection quantity: 11 - 45 = 2.2 - 9.0 mg/stroke
Manifold Absolute Pressure
Atmospheric pressure
Engine coolant temperature: 80 - 35 = 80 - 110 degrees C
Intake Manifold Temperature: 182 - 50 = 10 - 110 degrees C
Fuel Temperature: 91 - 201 = 20 - 80 degrees C
Air mass: 69 - 111 = 230 - 370 mg/H
These are valid ranges only when the EGR is switched on, engine at idle and at least 80C (176F) coolant temp.
Group 001 (injected quantity)
Engine RPM: 870 - 950
Injected quantity: 2.2 - 9.0 mg/H
Modulating piston displacement sensor voltage: 1.450 - 2.000 V
Engine coolant temperature sensor: 80 - 110 C
If below 2.2 - injection is running too rich
If above 9.0 - injection is running too lean, or the engine is cold
If below 1.450 volts - injection too rich
If above 2.000 volts - injection is too lean, or engine is cold
Group 002 (idle speed)
Engine rpm: 870 - 950
Operating condition: 010
Engine coolant temperature: 80 - 110 C
Throttle should go 0 - 100 depending on pressure applied to "go" pedal
Operating condition left digit: 1 = idle increased because AC is on
Operating condition middle digit: Closed throttle position switch is closed (foot not on pedal)
Operating condition right digit: AC compressor switched on
Group 003 (EGR)
Air mass drawn in (specified): 230 - 370 mg/H
Air mass drawn in (actual): 230 - 370 mg/H
EGR vacuum solenoid duty cycle: 40 - 75 %
If air mass specified is above 370, engine too cold.
If air mass actual is below 230 mg/H, excessive EGR or an air leak.
If air mass actual is above 370 mg/H, engine is cold, insufficient EGR, or bad MAF sensor
(Note: EGR is turned off after approximately 2 minutes of idle. Reading should be within that time period.)
If a DTC is present, air mass actual will have a constant value of approx. 550mg/H over the complete RPM and load range.
Group 004 (Start of injection)
Start of injection (specified): 2 ATDC - 3 BTDC
Start of injection (actual): 2 ATDC - 3 BTDC
Cold start injector duty cycle: 3 - 80%
If start of injection (specified) is earlier than 3 BTDC, engine too cold.
If start of injection (actual) is before 3 BTDC, engine too cold, injection pump set too advanced, or cold start injector inoperative.
If start of injction (actual) is later than 2 ATDC, injection pump is set too retarded, injection adjustment blocked, or cold start injector inoperative.
Group 005 (starting conditions)
Engine speed
Starting quantity
This is not useful for troubleshooting.
Group 006 (test with ignition switch on)
Speed
Brake pedal monitor
Cruise control system
Cruise control system (indicates if activated, 0 = activated but switched off, 1 = activated, swtiched on, 255 = not activated)
Cruise control system left digit: Clutch switch closed (clutch not depressed) = 0, 1 = clutch depressed
Cruise control system middle digit: CC/DFI brake pedal switch open (brake pedal depressed) = 1, 0 = pedal not depressed
Cruise control system right digit: brake light switch depressed pedal = 1, not depressed = 0
Right cruise control system 6 digit display has a 1, left to right, when:
Clutch operated
Brake pedal operated
Resume speed operated on the switch
Acceleration operated on the switch
Cruise control and memory switched off
Cruise controll system switched on
Group 007 (Temperatures)
Fuel Temperature
Nothing
Air intake temperature
If the car has been sitting overnight (for example) these should all equate to approximately ambient air temperature. If not a sensor may be bad.
If fuel temp indicates -5.4C, there is a short circuit or the sensor is bad/inoperative.
If air temp indicates approx. 136.8C (275F) the air temp sensor is bad/inoperative. Check for a DTC.
If coolant temp sensor indicates a large deviation from ambient temp, there may be a short circuit or the ECT sensor is bad/inoperative.
Group 008
Injection limitation when warm/full throttle/3rd gear @ 3000 RPM
Engine rpm (2900-3100)
Injection quantity requested mg/R (40.0-42.0)
Injection quantity rpm limit mg/R (35.5-36.5)
Injection quantity MAF limit mg/R (36.0-39.0)
Group 009 (injection quantity limitation)
Engine rpm
Injection quantity (cruise control system active)
Injection quantity limit signal from automatic transmission controler during gear change
Nothing
Group 010
Air system warm/full throttle/3rd gear @ 3000 RPM
MAF sensor: 800-1000
Barometric pressure
MAP (boost): 1700-2080
Throttle position %: 100
Group 011
Charge pressure control warm/full throttle/3rd gear @ 3000 RPM
Engine rpm
Specified MAP: 1850-1950
Actual MAP: 1700-2080
MAP Valve DC: 45-95
Group 012
Glow Status
Glow period
Suply voltage from ECM
Not useful for troubleshooting.
Group 013
This group shows the smooth running control injected quantity cylinder 1 - 4, left to right. Values expected -2.0 - + 2.0 mg/R
This is showing how the ECM is balancing the power for each cylinder at idle to account for variations in component tolerances, jet sizes, compressions, etc.).
Group 015 (fuel consumption)
Engine rpm
Injected quantity (actual)
Fuel consumption
Injection requirement (as indicated by the go pedal)
Group 016 (additional heater)
Generator loading
Additional heater
Activation of heater elements
Voltage supply from ECM
Additional heater display is 8 digit number where, left to right, 1 =
nothing
nothing
ECT sensor inoperative
engine started within the last 10 seconds
engine speed below 870 rpm
battery voltage below 9 volts
generator inoperative
ECT exceeds 70 C-80C (158F - 176F), or intake air temp exceeds 5C (41F)
Activation of heater elements is a 2 digit number. Left digit = 1 when high heat output relay is on. Right digit = 1 when low heat output relay is on.
Group 017 readiness code
Not relevant
binary code: x000xxxx
Not relevant
binary code: 0xxxxxxx
These may represent ready (0) for "Comprehensive component", "Misfire", and "Fuel system" in the first code and "EGR system" in the second. I have not verified.
Group 018
Speed
binary bits: 00
nothing
nothing
Group 019 (Quantity adjuster)
Voltage from modulating piston displacement sensor: 0.500 - 0.970 V
Voltage from piston displacement sensor: 4.150 - 4.740 V
nothing
nothing
If specfied values are out of tolerance, possible malfunction of the injection pump quantity adjuster.
Group 020
Ignition timing
Absolute pressure
Speed
Load
Group 021
Fuel Temperature
Intake Air Temperature
Absolute pressure
Load
Group 022
Binary bits
Unknown
Binary bits
Binary bits
Group 026
An undocumented field
Groups 027-040
nothing in any field
Groups 041-079
Not valid
Group 080
Jibberish
Group 081-085
Nothing in any field
Group 086-124
Not valid
Group 125 CAN bus communiation status
Auto. trans. controller: Transmission 1
ABS status: ABS 1
Instrument status: Instruments 1
Airbag status: Airbag 1
Group 126-129
Group 130-255
Not valid
(edited to add undocumented-on-the-CD groups)
<small>[ February 20, 2003, 20:06: Message edited by: MOGolf ]</small>
From left to right
Group 003 (EGR)
Engine speed
Starting quantity
Speed
Brake pedal monitor
Clutch operated
Fuel Temperature
Nothing
Group 008
Engine rpm
Nothing
Group 010
Barometric pressure
Group 011
Engine rpm
MAP Valve DC: 45-95
Group 012
Glow Status
Glow period
Group 013
Engine rpm
Fuel consumption
Generator loading
Additional heater
nothing
nothing
Not relevant
Not relevant
Group 018
Speed
binary bits: 00
nothing
nothing
nothing
nothing
Group 020
Ignition timing
Absolute pressure
Speed
Load
Group 021
Fuel Temperature
Absolute pressure
Load
Group 022
Binary bits
Unknown
Binary bits
Binary bits
Group 026
Groups 027-040
Groups 041-079
Not valid
Group 080
Jibberish
Group 081-085
Group 086-124
Not valid
ABS status: ABS 1
Group 126-129
Group 130-255
Not valid
