A4 G/J Convenience system w/p.w. VAG-COM measuring blocks
MOGolf
underneath something
Convenience system w/power windows VAG-COM readings
Based on Bentley CD info. Blocks are listed as they appear left to right. Actual values displayed may vary.
Group 001 (driver's door) through May 2001
Child safety switch: off, on, not installed
Driver interior locking switch: lock, unlock, not operated, implausible
Driver electric window - Hall signal: turns, still
Nothing
Group 001 (driver's door) from June 2001
Electric window - Hall signal: Auto. open, auto. close, man. open, man. close, not operated, implausible
Electric window thermal limiter: yes or no
Child safety switch: yes, no, not installed
Nothing
The thermal limiter is software controlled. It can be switched off for 10 to 20 seconds.
Group 002 (driver's door) through May 2001
Switch for driver door window: Auto. open, auto. close, man. open, man. close, not operated, implausible
Switch for passenger door window: Auto. open, auto. close, man. open, man. close, not operated, implausible
Switch for rear left door window: Auto. open, auto. close, man. open, man. close, not operated, implausible
Switch for right rear door window: Auto. open, auto. close, man. open, man. close, not operated, implausible
Group 002 (driver's door) from June 2001
Switch for front passenger door window: Auto. open, auto. close, man. open, man. close, not operated, implausible
Nothing
Group 003 (driver's door) through May 2001
Driver locking key switch: open, closed, not operated, implausible
Driver window thermal limiter/latch switch: active (0), inactive (1)/dr. open (1), dr. closed (0)
Driver side feedback: locked, unlocked
Driver side feedback: safe, not safe
Group 003 (driver's door) from June 2001
Mirror adjustment switch for driver's door: Pos X+, Pos X-, Pos Y+, Pos Y-, not operated
Mirror selection switch: left, right, fold, not operated
Nothing
Heating: on, off, not installed
Group 004 (driver's door) through May 2001
Mirror release switch: released, engaged, not installed
Nothing
Group 004 (front passenger door) from June 2001
Electric window switch: Auto. open, auto. close, man. open, man. close, not operated, implausible
Thermal limiter: yes, no
Nothing
Nothing
Group 005 (front passenger door) through May 2001
Window switch: Auto. open, auto. close, man. open, man. close, not operated, implausible
Interior lock switch: lock, unlock, not oper., implausible
Nothing
Group 005 (rear doors) from June 2001
Left rear window switch: Auto. open, auto. close, man. open, man. close, not operated, implausible
Left rear thermal limiter: yes, no
Right rear window switch: Auto. open, auto. close, man. open, man. close, not operated, implausible
Right rear thermal limiter: yes, no
Group 006 (passenger door) through May 2001
Locking key switch: open, closed, not operated, implausible
Window thermal limiter/latch switch: active (0), inactive (1)/dr. open (1), dr. closed (0)
Locking feedback: locked, unlocked
Locking feedback: safe, not safe
Group 006 from June 2001
Vehicle system voltage
Ignition: on, off
S-contact: operated, not operated
Speed signal: km/h. Increments in 2 km/h.
Group 007 (right rear door) through May 2001
Group 007 (Driver and passenger doors) from June 2001
Driver central locking key switch: open, close, not operated, implausible
Passenger locking key switch: open, close, not operated, implausible
Passenger interior locking switch: lock, unlock, not operated, implausible
Group 008 (left rear door) through May 2001
Group 008 (control unit) from June 2001
Hood contact switch: operated, not operated, not installed
Rear liftgate/lid key switch: open, closed, not oper, implausible
Rear liftgate/lid contact switch: open, closed
Thermo protection: yes, no
Group 009 (control unit) through May 2001
Illumination: 0 - 100 %
Speed signal: km/h (incremented in 2 km/h)
Remote key button: open, closed, RLR (remote lid release), Panic
Interior monitor sensor: yes, no, not installed
Group 009 (control unit) from June 2001
Driver side feedback: safe, not safe, locked, unlocked
Passenger side feedback: safe, not safe, locked, unlocked
Left rear feedback: safe, not safe, locked, unlocked
Right rear feedback: safe, not safe, locked, unlocked
Group 010 (control unit) through May 2001
Mirror heating: on, off, not operated
Trunk lid/hatch key switch: open, closed, not oper., implausible
Ignition: Term. 15 on, Term. 15 off
Group 010 (control unit) from June 2001
Drivers door lock contact switch: door open (1), door closed (0)
Passenger door lock contact switch: door open (1), door closed (0)
Left rear door lock contact switch: door open (1), door closed (0)
Right rear door lock contact switch: door open (1), door closed (0)
Group 011 (control unit) through May 2001
Hood switch: operated, not operated, not installed
Trunk lid/hatch contact switch: open, closed
Sunroof released: yes, no
Nothing
Group 011 (control unit) from June 2001
Immobilizer key recognition: yes, no, not installed
Automatic lock/unlock switch: operated, not oper., implausible
Sliding/tilting sunroof released: yes, no
Two-wire: two-wire (this is good), one-wire (this is bad) - data bus wiring
Group 012 through May 2001
Check bus: Bus OK, Bus not OK
Front equipment: driver, passenger, driver and passenger, nothing
Rear equipment: RL, RL and RR, RR, nothing
Optional equipment: Memory, nothing
Group 012 from June 2001
Driver door control unit: dr door = OK, dr door 0 = not OK. This means the centrol controller is not communicating with the controller in the driver's door.
Passenger door control unit: ps door = OK, ps door 0 = not OK
Left rear door control unit: RL door = OK, RL door 0 = not OK
Right rear door control unit: RR door = OK, RR door 0 = not OK
Group 013 through May 2001
Permanent code known: OK, not OK
Code within effective range: OK, not OK
Algorithm: OK, not OK
Key number: 0 - 4 (when key is operated, the key position is shown. If 0 is shown when key is operated it must be resynchronized.
Group 013 from June 2001
Rear lid button and handle: not oper, TG hndl op, implausible
Rear first detent: open, closed, not installed
Instrument illumination: 0 - 100 %
Empty
Group 014 through May 2001
Vehicle voltage
Trunk lid button and handle: not oper., TG hndl op, implausible
Interior monitor switch: on, off, not installed
Central locking switch thermo protections: 0=cut off, 1=operation
(5 digits)
Group 014 from June 2001
Group 015 through May 2001
Last alarm source
Penultimate alarm source
3rd last alarm source
4th last alarm source
values: 1 = rear lid/hatch, 2 = right rear door, 4 = left rear door, 8 = front passenger, 16 = ignition, 17 = immobilizer, 32 = interior monitor, 64 = hood, 128 = driver door, 255 = no alarm
Group 015 from June 2001
Remote key button: open, closed, RLR (remote lid release), Panic,
Nothing
Group 016 through May 2001
Immobilizer key recognition: yes, no, not fitted
Automatic lock/unlock switch: not relevant
Rear first detent: open, closed, not fitted
Nothing
Group 016 from June 2001
Last alarm source
turbonem
southpark,CO (fairplay)
'02jetta wagon red
so is there way to make the computer think the door is closed when it is open so as not to trip the door chime? it allways seems to wake up the kid's. The doors i am intrested in are the two front doors,or all doors for that matter. Thanks, MOGOLF for your expertise.... turbonem
LuvaDub
FLORIDA
2K TDI NB
[ QUOTE ]
[/ QUOTE ]
I don't believe that the door chimes unless your headlights are on or your keys are in the ignition.
VDubVerruckt
Scottsdale, Arizona
2003 Golf GL, Reflex Silver
You could always switch your cluster to U.K. settings you won't get the door chime anymore. You'll have to deal with military time being displayed in your clock though.
Gti5notrkt
I have an 04 TDI GL. The rear doors locking every time I drive is a PITA. Every time I get out to get the kid out the back seat I have to re-unlock the doors. Already re-coded via VAG-COM to unlock all doors in one press, but I am a little lost on which group to change to turn off the auto-lock feature. Is it this section?;
Thanks,
pepper10
Manchester, NH, USA
:)2002 A4 TDI , 2006 A5:)
I had the same problem. You have 2 options: cancel the auto lock or have th edoors unlock when you remove the key.
Lock/Unlock Horn/Flash:
[Select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Adaptation - 10]
Channel (03..08)
Adaptation Value (1 = on, 0 = off)
[Save]
Channel 03 Auto Lock set to 0 to cancel auto lock
Channel 04 Auto Unlock Set to 1 to unlock by removing key from ignition
Channel 05 Unlock, horn sounds
Channel 06 Lock, horn sounds
Channel 07 Unlock, turn signals flash
Channel 08 Lock, turn signals flash
Gti5notrkt
[Select]
[Adaptation - 10]
Channel (03..08)
[Save]
Mega kudos for that. Thanks.
Sputterputz
Chattanooga, TN
03 TDI reflex
MOGOLF I have a question... Can I turn the alarm off... OR I need to be able to recalibrate my remote for my car... I cannot do it until I get a new Door latch modual b/c mine is confused... it doesnt know when the door is opened or closed or anything.. SO if I could turn my alarm off temporarily it would prevent the possibility that my alarm gets set on accident and I cannot drive my car...
MOGolf
Not that I'm aware of.
mobandy
Here, where else?
Hope this is the correct place to ask this. Does anyone know if there is a way to have the headlight switch turn the headlights off instead of them being on anytime the parking brake is released?
Thanks,
Morris
moondawg
Columbus, IN
2001 Galactic Blue Jetta
Thanks,
Morris
This is not a software controlled feature. (sadly) You need, to bend, remove, or otherwise insulate the pin in the headlight switch that controls the Daytime Running Lights. Do a search of the forums for DRL.
moondawg
mobandy
Here, where else?
Unbelievable!!!! Actually that was my suspicion. I was hoping against hope that I was just overlooking it in VAG-COM. When you consider some of the things that are computer controlled though it is a bit surprising that the daytime running lights are not. Thanks for taking the time to reply. I appreciate it.
Thanks,
Morris
golightfoot
Ottawa, Ont.
2003 Jetta Wagon, Mojave Beige,
Hallelujah - my (almost) two year battle with the autolock system is over! Turned it off yesterday with the information seen here and my basic VAG-COM license. Thanks everyone.
Mrrogers1
Omaha NEEEBRASKA
2011 Golf TDI 6MT, 2011 Jetta TDI DSG, 2015 Golf Sportwagen S TDI DSG, 2010 JSW TDI 6MT
I'm pretty new to the VAG and heard that there is a way to control the window roll up and roll down through the remote, rather then using the key in the door.
Is that true and if so, what measuring block gets me to it?:confused:
ETA: I found what I needed and it can be done on the "Golf 5" vehicles for sure
http://www.ross-tech.com/vag-com/cars/Golf5.html
onehotspud
Grand Rapids, MI
2001 Jetta TDI
Up from the grave this thread arose!!!
Look here for one way to do it. The other is to buy the KVW100 from World Impex. There is no known way to do it using VAG-COM.
tos
Finland
Skoda Yeti 2.0TDI 4x4 DSG
Car without keyless entry
I have -99 Golf TDI without OEM keyless entry.
Can I somehow recode the central convience system, until it will accepts OEM tansmitter/keyfob?
I have transimitter HLO 1J0 959 A
1J0 959 799 H
soft coding 00257
WSC 01317
Extra: 1J1959801C 04 Tõrsteuerger . FS0001 | 1J1959802D 04 Tõrsteuerger. BF0001
Thank you !
and
Happy new year 2007 and sorry about my english;)
SilverGhost
Back in So Flo - St Lucie
First; that is the manufacture code (Hella) and about 2/3 of the part number. Drop the HLO and there should be three more numbers between 959 and A. Example from my car; 1J0 959 753 AH. And don't worry, the letters at the end are changes made to the original part so A would be the first time the part was changed.
tos said:
1J0 959 799 H
soft coding 00257
WSC 01317
Thank you !
and
Hopefully someone will chime in about the exact part number, but I think you have to have the comfort module made for remotes. The receiver and antena are probably missing from your car because it did not come with remotes.
Maybe post over in the forum for upgrades non-TDI engine relate?
tos
Finland
Hmm I made some spelling mistake, and forgot those 3 numbers.
Here is a picture from the transmitter:
http://tos.pp.fi/koukku/DSC09118.JPG
:eek: My comfort module will open and close windows, when i keep my car keys into the lock and turn them. (i dont know the right spelling)
I have to ask from vw vortex forums...
Thank you :)
SilverGhost
Thank you :)
Yeah, VW sometimes drops part of the part number off for unknown reasons. :confused:
If you send me your VIN (serial number of your car) I can check the PR codes to see if you have a comfort module that supports remotes.
tos
Finland
I sent an email to your msn IM adress.
Dunno513
Mirror Lake, NH
2006 NB PD-TDI DSG
ECS Tuning has this as a "NEW PRODUCT" currently backordered.
It appears to be for the A4's since the new A5's can be programmed via Vag-Com
KVW100 Window Roll Up/Down Flash Load Module
Control Volkswagen windows and sunroof with your remote keyfob.
For years Audi owners have had the luxury of being able to control window up and down functions via keyfob remote. Now Volkswagen owners can enjoy the same feature! The KVW100 is a single use flash load device that will program your VW convenience control module with the necessary coding to control your windows via key fob remote. Installation is extremely easy and can be completed in minutes. Please note this is not a feature that can be enabled via VAG-COM this unit flashes the convenience control module with new coding.Modules 1C0 or 6Q0
Modules 1C0 or 6Q0
  • One touch lock button :: Windows and sunroof roll up and close automatically
  • Double tap lock button (lock+lock) :: Windows and sunroof maintain original position
  • Hold remote unlock button :: Windows will roll down until unlock button is released
Modules 1J0
  • Press and hold lock :: Windows and sunroof roll up and close until button released
  • Press and hold unlock :: Windows roll down until button is released
ReferenceDesign
Atlanta, Ga
I just purchased the KVW100 from www.vagproduct.com in China. It is a one use device that plugs to the obdII connector and flashes the convenience module, probably similar to what the VDS-Pro tool allows you to do.
One issue is with key coding. Have all the keys coded that you will want to work with the system as I think the flash from the KVW100 is undone if the key profile is changed.
I also ordered the VAGtacho USB cable and read my 4 digit SKC (secret key code) on a 2000 TDI and a 2001.5 1.8T. And then made a key work!
The cable cost $60. The dealer wants $100 for one car. No brainer. Almost forgot, they have key sets with blank blades w/remote for $40.
Total dealer for one key $260. Total www.varproduct.com for one key $100 and I can do it again for $40.
BTW if you set the immo number of keys to zero the car will run with blank keys but the Immo light in the cluster will flash at a faster rate all the time.
SilverGhost
Modules 1C0 or 6Q0
Modules 1J0
One word of caution. As I just figured out reading over in the VDS PRO power folding mirror thread, once you have used the KVW1000 you will no longer be able to read/write eeprom. Also there are some bugs in it that have other members scambling to fix (like the alarm horn not working and the rear hatch issue).
After all this I have this sumery; if all you want is to roll your windows up or down with the remotes then get a KVW1000, however if you want to (or think you might in the future) change other settings then DON'T use the KVW1000.
Jason
AndyPee!!
Midlands
Golf tdi 90bhp
Convenience..Door issue
Hi, everyone...
Have an issue with my back doors on my 98 golf mk4, which im told is the convenience module....basically back doors wont open/like child locks are on and the drivers side central locking not working either...
'Sound about right? how do i know which module i need and is it expensive to get fitted or DIY? thanks
Goran10
Serbia
Passat B5.5 1.9 96KW Variant
Is there any way by using VAG COM to be sure that central convenience unit is working properly? I am asking this because I have a problem with mine, and the unit is dry (no water leaking), altough I see that some wires show corrosion on them, so that could be a problem.
But anyway, can we, using VAG-COM safely conclude that unit is functioning properly, or not?
Craig1977
Canada
2001 jetta
I'm new to the forum and the club, and I've yet to receive my HEX-CAN interface that I've just ordered. I've a 2001 TDI jetta, 140,000 k, and am recieving PO380 codes, (Glow plug/Heat), of which I can delete for a day or two, before it re appears, and with it the check engine light. I've checked the glow plugs according to Glow-Plugs 101, and I've found nothing so my guess is the harness or the controller. But it starts fine, and I'm wondering if I can use the VAG-Com interface and software to stop my car from seeing this code, hence keeping the check engine light off? Any insights would be great
SilverGhost
This thread is for CCM. I'll PM you about your glow plugs
Jason
