seancook1983
so I have owned my A3 8P PD 170 BMN for only a year and since owning the car it has always been a pain in the back side to start it that car been left over night. I spent 8 months chasing the problem and replacing parts with no success, I replace the Lift pump, the HP fuel pump, fuel filter, glow plugs, battery, fuel lines, coolant temp sensor & more but nothing fixed it. So I had a look at the service history I got with the car and noticed the injectors had been replace on a recall back in 2012 and thought just what if they never got every bit of air out of the fuel system after replacing the the injector. So I fired up VCDS and Run a manual Lift pump run, it runs the lift pump and pressures the fuel system for 30 seconds, I done this 6 times in total and then left the car for 2 days. Went outside after 2 days with not much hope as it was 3 degrees temp turned the key and fired instantly, wasn't sure if it was luck so left again for a few days and again started instantly and has done ever since. So my thought is that there has been some sort of air lock in the fuel system since the injector recall and its been causing fuel pressure to drop over night making it a pain to start.
