tjg
So I like the stage 2 rawtek/malone setup on my sportwagen so much that I bought a '13 A3 to go CR170 Stage 3 with.
It's a titanium/sport package, so pretty rare for a TDI A3.
Here's my shopping list. The green is what I've purchased already, the grey/lined out is stuff I no longer need, and on the right column you can see the prices:
Combing through all the info (on TDIclub) covering the CR170 swap, here's my full list of what I need:
-Gaskets
--8x copper pinch nuts: N90200201
--Oil return line gasket: 03L145757Q
--2x oil return line o-rings: N90715601
--Oil return block copper seals - unknown part number, I didn't replace
--EGR manifold gasket: 038131547A
--EGR intake gasket: 069131547D
--Exhaust manifold gasket: 03L253039B
--Downpipe gasket: 1K0253115T
-CR170 Turbo
-Turbo Inlet Pipes
-EGT Spacer
Here's the various parts so far:
Turbo, Gasket kit, inlet pipe, EGT spacer from tunemyeuro/aarodriguez
EGT delete and braided oil line from Darkside:
I have the Transmission tuner on order from Malone, should hopefully ship soon.
I'm going to order a Rawtek downpipe, but unfortunately they don't offer a full exhaust for the A3. Minor inconvenience.
I also have on order an oil change kit and the turbo lube coming from IDparts.com
-Gaskets
-CR170 Turbo
-Turbo Inlet Pipes
-EGT Spacer
