A Truly Hidden Hitch (when not in use) FINISHED!
DIESELprogrammer
NorEastern, Washington, USA
Golf GLS, 2003, Silver/Gray
Select FINISHED!
Several of you have emailed me with inquiries about the hitch I have designed for my 03 Golf. You all want to see the final result and many have asked the process that I used to create the design. At this moment I am waiting for the steel distributor to call and tell me my materials are ready. When they are, I expect about two weekends to get the assembly, welding and installation done. Until then, I thought I would try to answer some of your questions and give you a look at what I have so far.
My design criteria for the hitch was as follows:
1. No drilling into the interior of the vehicle.
2. No disabling of the 5/8mph rear bumper
3. No cutting of anything
4. Completely stealth when not in use.
5. Stronger than the standard NA hitch.
I started out by lifting the car and removing the rear - wheels, fender well liners, bumper assembly, valance, and fuel fill cover. I also dropped the muffler and muffler shield. Then I took about 40 pictures and measured just about anything I could imagine. Typically holding the measuring devices in place while taking the picture. I then put everything back together.
Next, at the computer I manipulated and printed several of the photos. Also during this time frame, my car had several occasions with the back-end raised on the ramps while I lay there staring at its underside, trying to get ideas for the hitch design. Most of the time I carried the ramps and a pair of coveralls with me to work so that I could check things out in the parking lot during my lunch hour. I also used a plumb-bob and level to project measurements down to the floor and establish elevations.
I decided on these four points on each sub-frame for mounting the permanent frame rail components.
Back at the computer with an idea, I began generating 3D solid models of all of the components and assembled them at they would be welded together. I was also able to visualize the assembly on the car by overlaying model renderings onto photos of the car.
The cross bar below is 46” long to work with a 46”x20” carrier that will slip into the outside tubes. When the carrier is not in use the tube ends can be covered with rubber cups. The hitch is shown white here and without gussets and fasteners for clarity. The final product will be painted to match the valance. The bottom of the crossbar sits .125” below the bottom edge of the valance
At its lowest point (bottom of receiver ring), the hitch sits exactly 2” below the bottom lip of the valance.
This second design shows the crossbar cut back flush, with the tubes mitered.
I then generated a material cutlist from the component models. From the cut list I made physical models out of appropriate thickness cardboard. Hot gluing them together as they would be welded. After several fittings under the car and consultations with a couple dozen steel distributors and fabrication shops, I ended up making 5 different models because of fitting issues, material availability, and manufacturing cost. In the end, the final design turned out to be a class II assembly.
Keep in mind that all of the hitch assembly that you see in these pictures is easily removable (less than a minute if pinned – probably less than five if bolted). When removed nothing is visible in any view except when looking behind the valance, up from underneath to the sub-frame.
alhutch
Portland, Oregon
None
A Truly Hidden Hitch (when not in use) Update
Don - That is a very comprehensive look at the hitch issue! When can I pick mine up??? /images/graemlins/grin.gif
I hope you post more pictures once you get it fabbed and brackets installed. - Al
Growler
Got Soot Vendor
Millersport, Ohio
by any chance are you going to be offering these for sale/?
and will it fit a NB?
unixb0y
Manitoba, Canada
2013 Passat Comfortline 6MT Nav
awsome!
I can't wait to see it finished.
I bet this would work great
Smaller 4' black solid steel platform. Hauls up to a 1/4 ton capacity, black powder coast finish, expanded metal mesh floor, 12 tie down holes, pre punched holes for mounting HITCH-HAUL
http://www.masterbuilt.com/store/hp248.html
or
· Easy to install, use and store.
· Fits either 1.25" and 2" hitch receiver
· Carries up to 2 bikes.
· Rubberized hooks to protect bike finish.
· High-grade (14 gauge) powder-coated steel.
· Fits all bike frames and sizes.
· Center post tilts away for easy rear car access.
http://www.sportrack.com/a30901
DIESELprogrammer
[ QUOTE ]
[/ QUOTE ]
I have to have a hitch on my Golf by July for a trip to Alaska. I just didn’t want to drill into the interior or have a permanent hitch hanging down low on the rear of the car like the NA hitches. In addition, I didn’t want to disable the 5/8mph rear bumper with a Euro hitch. The cost of the Euro hitch was also a consideration. However, final cost of this setup and my time will way exceed that cost.
[ QUOTE ]
[/ QUOTE ]
See reply to next post
[ QUOTE ]
[/ QUOTE ]
I am detailing the assembly and installation with many pictures. Will post some when finished.
DIESELprogrammer
[ QUOTE ]
[/ QUOTE ]
I have considered building them myself or perhaps work out a deal with a local fab shop to make them for me to distribute. I once spent 8 years as a journeyman metal worker and had several welding certifications. However, I am not sure I would want to take on all of the liability issues myself.
Another option I have considered is selling or giving away the material list, complete shop drawings, and a detailed set of assembly and installation instructions. From these, anyone could have a local hitch fab shop build/install the setup for them.
[ QUOTE ]
[/ QUOTE ]
As for the NB, it is my understanding that its chassis is identical to the Golf, right back to the rear bumper mounts. If so, that would mean that this setup would work fine. The only adjustments MIGHT be to address rear valance clearance and bumper distance from bumper mounts rearward. Both of these would be easy to adjust if needed. I just need a NB to look at – perhaps at the next GTG I attend.
DIESELprogrammer
[ QUOTE ]
awsome!
[/ QUOTE ]
That is very similar to what I am also building. Except mine will be 46”x20” (I wanted to keep more tail light showing) and it will slip into the two outside tubes. This is to make it more stable and distributes the weight directly out, instead of to the center receiver first. The material for platform was ordered with the hitch materials and it will be built shortly after. It will be great for day trips - haul coolers, etc, on it and leave more room in the car for the dog.
Remember that the hitch is going to be a Class II so the max tongue weight is #350. I doubt that I would want to go over #250 though. We will see how it looks loaded at different weights.
If anyone has used one of these on their hitch, perhaps they could offer some incite to real world capacity.
jackbombay
Diesel knows best
A4 Jetta
Looking forward to seeing the finished product, thanks for sharing your info!
-Jack
BAMA TDI
South Who\'lda Thought It
I hope it won't take too many alterations to fit an A4 Jetta. I am beginning to need one. The Euro one is too expensive for me at this time and I don't like the fact that with it you lose the 5 mph bumper capability. I don't like the others for the way you have to drill into the floor of the trunk and spare tire well. However, I may not be able to wait for your set up. Anyway, what you are making looks fantastic.
DIESELprogrammer
John...
I haven’t had the chance to look under a Jetta. Hoping to and also a NB at the next GTG that I can attend. My guess from pictures I have seen here on the site is that one new hole will have to be drilled in each sub-frame mount (my mount) to make use of the rear most factory hole in the Jetta’s sub-frame. Then because of the additional length back past the rear bumper, the two outer tubes (shown above) would have to be a little longer. Neither of these would be much of a design or cost issue.
BAMA TDI
Thanks Don,
Appreciate the time you are taking to do this. Too bad you live so far away. I would let you look under my Jetta.
Have a great weekend.
Regards,
unixb0y
Manitoba, Canada
[ QUOTE ]
John...
[/ QUOTE ]
Maybe the bar that fits the jetta could be used on the golf.
just a though.
DIESELprogrammer
[ QUOTE ]
just a though.
[/ QUOTE ]
The draw bar will probably be the same. It is the rear most stock sub-frame holes that look to be at a different location on the Jetta than the Golf. There is also a little more length from those holes to the rear most part of the bumper on the Jetta. So the outer tubes on the drawbar may have to be a couple inches longer?
Ian F
Croydon, PA
Jetta Wagon, 2003, Indigo Blue
I'm also thinking of hitch set-up for my Jetta wagon. Keep us posted! Thanks! /images/graemlins/grin.gif
astonishedboy
pickinoutthetitsburgh, PA
Y2k Golf, Black Mariah
Just want to show my enthusiasm...
YES!!!! this is awesome!
I would be very interested if these become available.
How high is it from the ground? Stock suspension?
alien8
CA.
Looks great Don , I too am interested in your hitch . How to keep updated with your project is the question .
dan
DIESELprogrammer
[ QUOTE ]
[/ QUOTE ]
I have been discussing the manufacture of these with a local shop. So I will let you know how that goes soon. Please keep in mind though that there is no way that these can sell as cheap as a Hidden type. Material cost alone are greater than that. However, material cost could drop some when ordering in mill lengths versus cut lengths. Just check locally for the price of a custom hitch and you will get more of an idea of cost.
With a Class II receiver – the receiver has an added ring around the receiver opening as compared to a Class I. See the revised pictures in the first post of this thread at points labeled “A” & “B”. This is the lowest point of the hitch assembly. According to my calculations, that point should be 1.875” below the bottom lip of the rear bumper’s valance. If a Class I receiver is used, that point would be 1.75”. This calculation allows for a .125” clearance between the valance and the hitch at point “C”.
So you should be able to park your car on a level surface and measure your ground clearance no matter what ride height you have. Even with the visible part of the hitch assembly installed, it sits higher than a Class I Hidden type hitch. With the only the sub-frame mounts and the visible portion of the hitch removed, nothing extends below the rear valance.
As for another update – I had planned to finish this last weekend, however the weather didn’t cooperate (power outage) and then I needed a part for my welder (ordered this am and will be in Thursday). We will now hope for next weekend.
LeeM
Hagerstown,MD
2015 Passat SE, 2002 Jetta Reflex Silver
If you do carry through with the manufacturing of these hitches, put me down for one for a 2002 Jetta.
DIESELprogrammer
The components are fabricated and ready to install. I am waiting to get my car back from the dealer – getting the coolant migration issue fixed.
As long as I get the car back in a timely manner, I should have the install complete next weekend. I’ll post pictures when it’s done.
mazot
MA, USA
We're looking forward to see the pictures. Have you installed it yet?
DIESELprogrammer
It is only 6 weeks behind schedule, but it is finally on! Just in time too. I am leaving for Alaska this Friday.
Here are a few pics. I apologies for the quality. I need to place something white down to reflect up or find a concrete patch to take some pictures on. When I do, I will post better pictures. Also, the paint job isn’t the greatest. I plan on sand blasting the assembly when I get home in August and then have it powder coated.
Here is the everything attached. The car and trailer are empty. I (230lbs) bounced on the trailer tongue while attached. All seems solid. I am giving everything a shakedown for the next couple of days – going to put about 1000lbs in the trailer tonight and haul it to work tomorrow. Should be about 1900lbs total.
1.
2.
3.
4.
My welds aren’t exactly my best. Considering, it has been 19 years since I welded professionally and 10 years since I fired up the welder at all, they are good enough and strong. All intersections are gusseted for additional strength.
5.
6.
This is one of the sub-frame brackets that mount permanently to the car. There is one for each frame rail and they bold to the factory hitch holes (arrows) and the two other locations shown. The square receiver tube is cold drawn seamless tubing. The “L” shaped drawbars pin into the square tubing here and on the visible portion of the hitch.
7.
The 3 bolts, each with a 2”x2”x1/8” sq washer - from the inside of the rear bumper shock absorber cavity (sub-frame).
8.
For I while I was beginning to question it. But in the end I accomplished my goal as stated earlier. No holes were drilled into the car and when the visible hitch portion and the “L” shaped drawbars are remove, nothing is visible below the rear valance. When I get back I am also going to make a cargo rack that slips into the outside tubes. I already have the steel.
Powder Hound
No need to apologize for the welds - they look great to me. Nice pattern, no spattering, no gaps, no holes, no bubbles, no burn through. What can you possibly think is sub-par about these?
estwing
Central Arkansas
Silver 04 Golf GL
The hitch looks great. I've haven't checked into it yet, but does an aftermarket hitch drill into the interior and disable the bumper?
So this bears the question, what is the towing capacity of a Golf?
jackbombay
Diesel knows best
A4 Jetta
Some aftermarkets drill into the spare tire well and the europSo ean ones disable the 5-MPH bumper.
DIESELprogrammer
Thanks for the kudos.
IMNSHO, welding is an art and something that takes continuous practice to maintain a high skill level. I was just being critical because at one time I could lay down a bead that was completely uniform from the start to the finish of the rod, with excellent penetration, and even buildup. With wire I could make the bead as smooth as glass.
In the weld pics above, you can see the small bulges in the bead caused by slight pauses in the progression of the rod. In the painted pic you can also see small variations in the climb of the weld onto each surface, making it not exactly strait. These don’t affect the strength of the welds; they just affect my perfectionist ego.
Gary Miyakawa
Admin Emeritus
Roswell, Ga
1998 NB TDI
If you have time, you might want to put a wedge on the front of the trailer (or on top of the car) to blow the air up and over the front of the trailer. If that's the trailer your going to pull, your going to have a pretty good wind brake there..
Gary M
RichC
Cincinnati, OH
Others: 82 MB 300D Turbodiesel & 2010 BMW X5 35D
Don,
Have a safe trip and report back how everything works out. I'll be anxious for you to put together the cargo carrier too as I think that gives your "Truly Hidden Hitch" double duty and will be far above any other hitch for the VWs.
You might contemplate a set of plans, measured drawing and materials list as I for one would be interested in purchasing them?
Again ... have a safe trip and I appreciate your engineering skill in putting your hitch together and sharing with us.
RichC
