BudsBug
I keep seeing the immobilizer key issue come up. I have 2 thoughts:
1st Kill the immobilizer
!! I wonder if the VAG-COM can disable this monster with some code. I would ask if any of the chippers may have seen a way to do this.
Can we fake it out using a wire that could be tied high, low or switched. If we knew the expected response we should be able to beat it as long as it isn't a code that is generated as a response I would expect a high true or low false of at most a state change IE. low high for a time 1/2 second than low.
2nd Has anyone attempted the remote starter trick whereas you wrap a thin (20-30 gage) wire around the key cylinder 3 times and around a good key 3x to send the code from the known key. This may require drilling out the transponder in the new key or using one of the steel keys with no transponder that people have gotten off of Ebay that wont work on their car and can't be programed.
We need to get a way from the 3 digit $$$.$$ key the cars. At some point will cars will be worth less than a new key for them
