blizzard60
^ that's exactly what I have. Do you find it kinda brutalizes the insulation sometimes? I looked at the ones vw sells but they are like $300 or something!!!!!!!!
To my knowledge (could be wrong), that one is only available in repair wire form.Hello
I'm looking for the pin for a bluetooth interface (54 pins)
With ETKA it's 000 979 010
Is is possible to buy this in buying group ??
Many thanks
Hmmm, I'm interested in this pin too. Are you putting the Touareg BT in your MKIV or passat? I'm doing this myself - do you know anyone who has done it yet?Hello
Many thanks
-Chris
000979133 = 3-7209 (most terminals on car 1.0mm wire)
Like graeme86 said, 000 979 133 is 1.0 mm wire. N 906 844 05 is the contact you will need. They are readily available at the dealer (usually). However, 14 gauge wire is going to be too thick. 1.0mm wire is somewhere around 18 gauge.Just want to be sure, is 000979133 the correct wire/terminals required to wire up front/rear fogs to the euroswitch?
I know there are premade kits available, but I want to try and build my own first and saw I actually accomplished something on my car
Would these fit onto 14gauge wire? Yes I know I'll have to source a proper crimper as well![]()
looking for the terminal of repair wire 000-979-151-E (the female side of 000-979-134 ( N 103 189 05 ))Thanks Graeme but I don't need this type of terminals, this type of terminals can be very easy ordered direct to vw dealer - these are some codes I know:
equivalent terminal for repair wire
000 979 131 <=> N 103 358 07
000 979 132 <=> N 103 361 05
000 979 133 <=> N 906 844 05
000 979 134 <=> N 103 189 05
The problem for me is that I need only gold plated terminals which unfortunately are not available through the vw dealer, so the only solution is to know te equivalent code direct from AMP/Tyco, and to find an online supplier which sales reasonable quantity like this one: http://www.masterdistributors.com/ordering/productdetail.cfm?pr=2372191 or http://www.onlinecomponents.com/buy/AMP-TYCO/963715-5/ and have them in stock.
So if anybody knows the equivalent code from AMP/Tyco of the vw repair wire gold plated terminals please help
000 979 009 A <=> 963715-5 or 962885-5
000 979 018 A <=> ?
000 979 023 <=> ?
000 979 131 A <=> 964274-3
000 979 132 A <=> ?
000 979 133 A <=> ?
000 979 134 A <=> ?
000 979 135 <=> ?
000 979 225 A <=> ?
000 979 226 A <=> ?
000 979 227 A <=> ?
Let's find the equivalent and put here the codes for those who need them ! (I will edit this post each time a new AMP/Tyco equivalent code for vw repair wire terminal will be found)
<off topic>Does anyone have a VAG part number for the pins used in 000979103 (male pins for W8 interior light connector)?
Ash![]()
I'd take you up on that offer if only I didn't need them in time for TuesdayHow many do you need? I'll do 10 for 5£ or $10 whichever is easier for you... Shipping included though it might take a couple weeks to get there...
Thank you<off topic>
I have nothing for you about this part but I just wanna say that I love your avatar !! (Even though it's a gasser cluster)
</off topic>
