What is this "heat zone" you speak of? Climatronic has digital setpoints.
If you have Climatronic turned off and you press OFF again, it will wake up and restore to your previous settings. Pressing AUTO will wake it up in automatic mode (with the AC on). Pressing other buttons will make it wake up into the mode for whichever button you pressed.
As mentioned in an earlier post, the Passat has a variable output compressor via a refrigerant control valve. The compressor itself is
always spinning, unlike an older compressor with a clutch that cycles. As you approach your zone temperature setpoint, the compressor unloads itself to maintain the desired temperature as efficiently as possible (older systems add heat rather than unloading the compressor). This is why there is very little fuel economy penalty for A/C use with Climatronic.*
Climatronic:
read more:
http://my.vw.com/2012-passat/comfort/climatronic-heating-cooling
Manual Climate Control:
read more:
http://my.vw.com/2013-passat/comfort/manual-climate-control
With the manual climate control, turning the temperature knob to the position shown in the pic (MAX A/C) will enable the compressor and engage the recirculation function. The detent on this knob position is very small and is easy to inadvertently select. If the system is off and you press OFF again, I suspect it will behave like the Climatronic system and restore to your previous settings.
On both climate control systems, pressing recirculate will also enable the compressor. This prevents humidity (from your breath) from building up in the cabin and subsequently fogging up the windows.
-----SIDEBAR-----
I
think, but have not confirmed that the temp dial on the manual climate control actually corresponds to a zone temperature setpoint, rather than just regulating a heat flapper or valve. To explain it a little differently, I think that, for example, straight up on the temp knob could be 74 degrees and you can go up and down from there. The computer will automatically regulate the compressor load and/or add heat as necessary to maintain your setpoint. Any HVAC gurus out there feel like doing some testing?
*Before someone points out the RCV in previous TDIs (dating back to the ALH and maybe before?): that only regulates the refrigerant flow based on evaporator temperature - not based on zone temperature like the new models.
