So...I went through the AC Guide and slowly started figuring out what's not working. I need to recheck power at the T4 connector because I miss interpreted the guide. Regarding grounds I have continuity from T4 4 to ground but NOT from T4 2. How do I troubleshoot that? Is that my issue?
I have continuity through the clutch coil.
T14 connector checks out fine, I think that's ok.
Macro level issues : Fans and Compressor will not kick on. Freon level is ok. Fuses are ok. A/C button lights up. I have continuity through the coil (but no power getting to compressor). I swapped the G65 sensor and FCM with different units and no change (though both parts were used).
Any ideas?
Any ideas?
