135 cc
From the Sanden manual:
6.8 Oil Charge
Oil Circulation Ratio (OCR) should be between 3.3% and 8% ratio of oil to refrigerant
by weight.
6.8.1 Oil Flow Theory
Compressor lubrication occurs as the oil which circulates with the refrigerant passes
through the compressor crankcase during operation. The Sanden SD series
compressor achieves optimal durability and cooling performance when oil circulates
through the system at a ratio of 3.3% to 8% oil to refrigerant. Excess oil can act as an
insulator limiting heat transfer in the evaporator and condenser, while too little oil can
negatively affect durability.
Oil will collect in low pressure cool components (evaporator, accumulator and suction
hose) of the refrigerant loop. For example a long suction hose which sags can collect
several ounces thus reducing overall oil circulation ratio.
6.8.2 Oil Charging
6.8.2.1 Passenger Car, Light Duty Truck Single Evaporator
Refrigerant charges 24oz (680g) to 40oz (1133g)
135cc oil TXV systems
• 240 cc oil in orifice tube systems
