greenskeeper
I'm not a fan of A/C but the wife and 2yr old son have different opinions
I have been using leak sealer charges for over 30 years without ever having a problem. I have used these charges to stop leaks in refrigerant lines, to seal dried out on O-rings, and even stopped leaks on the main seal on the compressor. If you follow the directions they work very well in swelling dried out O-rings that have leaked. There are even some sealer charges that contain a resin epoxy that can patch a leak in the coil of a evaporator and condenser. All this scare tactic of saying never use them is a pointless waste of a tool that many times can repair an ac system for years.
I speak from repairing over 200 auto ac systems in the last 30+ years. Many times when you start to repair a known issue in an older ac system the breaking of the system open to air causes new failures. Using a stop leak charge as I stated earlier can prevent other failure from happening during the repair.
I'm telling you, it will take more than one can of R134a. Look at your individuals car specs for the A/C system but I am guessing, when empty, it will take more than that. Low side, when cooling, should be in the 35-40 range.
I know it takes more than a can, don't want to waste r134 since it isn't cheap!o-ring fail
going to replace all o-rings and the dryer/accumlator
see what happens then.
from my research the system should take 28oz of ref and 3.9oz of oil if completely dry.
cheapest around here is $14.99 for a 10oz can of straight r134a
the low side shouldn't be over 100psi correct? More like 55psi according to my chart. when the A/C stops working (compressor kicks off) the low side reads over 100psi.Are you sure it's high pressure and not a low pressure switch?
low side was down to 15psi or so.What is the low side reading right before the compressor kicks off?
-J
I added some more refrig to bring the pressure up to reference the chart for 90F
I never got the presssure high enough according to the chart, now the compresssor cycles on and off repeatedly.
overfilled? even though I was well below what the chart said for 90F (around 45psi actual, chart said 55psi).
no leaks, bad o-ring and I replaced all of them while I was at it.That doesn't sounds overfilled to me. I've had my air happily running with a PSI low side around 40. I think you might have a bad expansion valve. It should not be this hard to get this thing running and keeping correct pressure. Otherwise, you may have a faster leak and it is not letting the system come to pressure at all. You really need to get some gauges on there and see what it going on. How does the compressor sound when it is running? Have you added any PAG oil in addition to the freon?
the brand new receiver/dryer was defective (leaked, although not all the time, weird) which I got from a source I use quite a lot. Disappointed but it happens.
New (2) receiver/dryer in place. Held vacuum overnite so I should be able to charge this morning once I get home from work.
"cross fingers"
