dremd
- Joined
- May 31, 2007
- Location
- South Louisiana
- TDI
- 06 sprinter. 03 jetta wagon premium with 6 speed ALH swap, 14 JSW
History: I bought the car in Iowa, in January, so A/C wasn't really on the mind, we had a cooler than normal spring, and the car was apart for the beginning of summer .
What I've done: I had to swap both a/c flexable hoses for the motor swap, so I opened the system, replaced the hoses, and the dryer, I then charged it with 750 grams R134a +/- 5 grams and 2 oz pag 46.
Fired it up, blew "cold" assumed all was well.
I've been driving it for a while and the A/C has been adequate, I was assuming that the climatronic had been throttling appropriately, but Sunday, I got hot (95f official temp, 99-100f on dash), so I've left it on recirculate, LO temp, and max fan since then ive realized performance is pretty darn poor.
I get dead minimum dash vent temp of 41 with blower at lowest setting, and about 52~55 F with the fans cranked. Testing done at 87F ambient after dark.
I'm seeing ~35 psi on the low side at idle, my gauges don't clip on to the high side of VW's (but work fine on everything else) so I don't know the high side psi, BUT the fans cycle from low to high so I assume that high side pressure is reasonable, or maybe a bit high.
Any ideas? I'm thinking expansion valve, but I'm hesitant to open the system again on a hunch.
Edit: I definitely pulled a VAC on the system for a good 1.5-2 hours before charging.
Also, not sure if it is climatronic related, or problem related, but compressor doesn't click on for several seconds (same amount every time) after engine start.
