JJUelmen
I have a post in TDI 101, but havent gotten any opinions as of yet. Only posting here in hopes that more people check this more then TDI 101. Below is my post:
This weekend I went to get a few things out of the car and the FOB didnt work. I figured it must be the battery and replaced it....didnt do it. Furthere when I go to start it, it doesnt even crank. The little red light on the driver door lock (that normally blinks when locked) does not blink anymore when the door is locked manually (FOB still not working). Glow plug light comes on so it's not relay 109. The TDIFAQ sheet listed ignition switch and then security system fault as the next two possible culprits. I would assume it is the security system fault since the FOB doesnt work and the light no longer blinks.
This may be completely unrelated, but the fuse for the dome light was blown when I checked all the fuses.
Suggestions and help would be much appreciated with the holiday season coming up as I will need to do a lot of traveling.
