Dwmorrissey17
I have a 99.5 alh jetta 5 speed. I'm having really goofy electrical issues. I bought the car as like the 9th owner so it's been passed around... It's recently burnt up 2 radios within a month. Started fine Monday morning, then went out for lunch No crank, no power windows, no sun roof, no trunk actuator. But if I turn the key on, jump 12v from the B terminal to the S terminal of the starter, it starts right up. No codes in vcds. Power out of all of the battery box fuse box connections. No blown fuses. 109 relay works and conducts as it should. Clutch switch works, cruise control works, lights all work. I've also had some door harness issues with the car, and none of the power window switches work in the car since the no crank issue. however all of the lock switches work. I'm buying a rust free 03 gls jetta this weekend so the 99 is on the back burner, but it would be nice to fix and sell or keep as a winter beater.
