99.5 ac delima
mrbowtieguy
North central Texas
99 Jetta
I've got a 99.5 jetta where the ac just quit the other day. system has a charge, all fuses check good on the battery top and on the end dash area. i removed each one and checked for corrosion.
The compressor does not kick in and also the blower fan does not come on.
The ac switch doesn't light up but the fresh air recirc switch does.
I was going to take the fan control module off my 01 but the connectors are different.
Will a scan with a vcds be helpful?
Any ideals?
Estergard87
USA
1999.5 Jetta
Any ideals?
VCDS wouldn't help. When my FCM failed, the AC light still lit up and the blower fans came on. I'd start here: http://forums.tdiclub.com/showthread.php?t=242699&highlight=FANS
