98 NB Odometer/Tripmeter too dim to read.
upsbroke
Homosassa, Florida
98 NB and '13 JSW
Haven't had any luck in my research but my 98 NB dash lights work just fine but the odometer/tripmeter numbers are so dim that they are unreadable. I'm sure someone e
Steve Addy
Iowa
97 Mk3
Sounds like the LCD panels (if that's what they used then) need to be replaced...or maybe even the cluster itself...which would be the easiest I think.
Steve
Lug_Nut
Sterling, MA. USA
2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700 1962 Quantum III
The back light used for the digital odometer / tripmeter is probably not separately replaceable in the Mark IV / A4 series New Beetle.
It was not replaceable in the Mark III / A3, nor in the B3, B4 (B3.5) Passat.
Steve Addy
Iowa
97 Mk3
I've replaced the LCD panels in a Mk3 cluster...they're really quite easy to swap out. Now NB I have not done so you could be right about those. His best bet may just be to get a replacement cluster and have the mileage reprogrammed vs futzing around with the LCDs.
Reminds me I should get a Mk4 cluster to dismantle and look at....
Steve
