I was just thinking about doing this myself.The current Green doesn't match my Alpine or my Sirius Blue.Diesel Dude said:Notes - The illumination bulbs have a green or blue socket and are 2 watts and the indicater bulbs are 1.1 watts and are orange. You have to just twist the sockets a quarter turn and they will come out.
is the procedure any different on the 1997 Jetta?Diesel Dude said:I just had my cluster out about an hour ago. Not a bad job.
1) Disconnect the battery ground.
2) Move the steering wheel to the lowest position.
3) Pry the plastic trim left of the light switch toward the drivers seat gently. It will pop off.
4) The light switch can now be removed. On the left side of the switch if youlook in the hole left by the removed trim there is a plastic catch. This has to be pushed to the right to remove the switch. Once the lock is released the switch will pull straight out far enough to remove the harness connecter.
5) Move to the piece of trim on the right of the cluster. It will pry off in the same way as the one on the left.
6) There are now 2 screws exposed (one on each side of the cluster trim) that need to be removed.
7) This trim piece was a little bit stuck on my car, but gently prying and wiggling freed it up and it pulled out.
8) Now there are two more screws, one on each side holding in the cluster. Remove them.
9) The cluster can now be tilted down to access the 2 electrical plugs, there are two tabs along the long side of each of the connecters that need to be squeezed before you can remove them.
10) Now the cluster can be lifted up and pulled directly out of the opening.
Good luck
You might have to swing your adjustable steering wheel all the way down to get it to come out.Growler said:is the procedure any different on the 1997 Jetta?
we were trying to get the cluster out of my dads jetta last night (to get the to glow plug fuse)
we got stuck after # 6 here. we got the two screws out at the bottom of the cluster trim, but when we pulled on it, it seemed like it was connected behind the dash vents at the top.
does the trim need removed from the steering column?
seems like the 1997 might be a little different unless we just need to try a little harder to get the top of the cluster trim away from the dash. it sure seemed like there were screws or something connecting it behind the vents..
grr.
IT'S EASY - GO FOR ITI just had my cluster out about an hour ago. Not a bad job.
Good luck
