'98 Jetta Engine Diagram?
Rowan
Silver City, NM
1998 Jetta TDI - Blue
I've done a lot of searches and can't find anything. I just need a simple diagram of labeled parts for reference on my '98 Jetta Engine (everything under the hood).
Anyone know of such a thing?
Duster408
Scranton, PA
1998 Jetta
Do you have a the Bentley Manual for your car? I believe there are pictures/diagrams in the first chapter showing the parts of the engine.
Lug_Nut
Sterling, Massachusetts. USA
idi: 1988 Bolens DGT1700H
That's the oil dipstick. Pull it out to see how much oil is in the engine.
That's the oil fill cap. If you need oil add it there.
That's the windshield washer jug. ........
What are you trying to identify?
That is the N18, it's used in conjunction with the VE I-Ps and gets command signals from the ECU.
Something in between those scenarios?
Uberhare
Ontario, Canada
Too many.
Sorry, must have been tired when I read your original post...I thought you were looking for wiring diagrams, not component location.
Stealth TDI
Newport News, VA
2017 GTI APR Stage 3 (395 hp/376 lb-ft)
He's looking for a road map. These are a bit big for forums; but they'll do:
European 1Z intake manifold... but the location is the same...
Have Fun!
dlasala
CT
'98 Jetta 1.9L TDI AHU
Can anyone point me in the right direction to find the part numbers for each of these parts in the diagram above?
I am looking to replace my turbo and want to buy replacement gaskets and fasteners before hand.
I have a 1998 Jetta AHU engine.
Thank you
Don
