I encountered a 98 Jetta Tdi today with that has a 2000 engine installed. The car will start, idle good, but doesn't seem to devope power, low end and up thru rpm. It runs like the turbo has no boost. I am not familiar with installing a ALH engine in the 98 jetta Tdi.
Has any one completed this type of upgrade, or engine swap?
The installer put the AHU IP on the car, and the 98 intake and exhaust manifolds. The car did not run properly, so the present owner took the car to the VW Dealership. They installed a new IP, water pump (water pump pully split), and the car still does not develop power.
The intake looks like it could use a cleaning, but I don't think it is restricting airflow to a point of congestion yet (this will be one of the first lines of attack if I work on the car again). The IP wiring has been reworked, I think to accomadate the new IP on the AHU wiring harness.
I am not sure if I want to open Pandoras Box, so if someone has the blueprints for doing this swap, I would be interested in talking to you.
One CEL, 0380, manifold temp sensor circuit. I do not know if the ECU was swapped, or if it could be. I think there is a different connector on the A3 and A4 year car.
All vacuum hoses, connecter, water hoses look to be routed a compatable destination.
