markward
Hello, I have a 98 ALH engine in my VW Vanagon. Have about 20,000 miles on the conversion. A problem showed up a little time ago, but was intermittent. Seems to happen more often. The engine starts fine cold, but if I drive it to temperature and then park it for 15mins, it will crank, but won't "catch"/run. Since it is a conversion, some of the obvious solutions are not applicable. Here is what I have done.
I redid all the power supplies to the ECU etc. I added a relay from the ignition switch to power the TDI ECU rather than running the ECU off the ignition switch. Vanagon's are notorius for ignition switches going bad. My ignition switch is relatively new. My Bentley shows the fuel cutoff valve getting power direct from the ECU. I have tried a jumper to power and to the solenoid just to be sure, but when it won't start, it is as if the solenoid is not opening. I can here something click. I removed the solenoid and visually tested it, it works fine. I reinstalled the switch and added a ground to the pump just to be sure. Same problem.
When it starts, the engine runs perfect, no smoke, miss or anything that would indicate an injector leaking down. The pump was resealled and has been fine for many miles. No visable leaks or smell.
Here is my question. I see the fuel cutoff valves for sale. I don't see how it could fail, but it seems to be "heat soak" that keeps the engine from restarting. Do these valves go bad? Can I pull the valve temporarily, remove the piston, install the valve and see if the problem goes away? I have never done that before.
I should add the shut down flap in the intake was removed some time ago. No codes, but is there a value I should be watching for when trying to start the engine in my VCDS software. It really is kicking my butt. Thank you mark
