For any of the guys drooling over 6 speed swaps, tell tdconversions to hurry up with their 1GR-FE adapter plate. Lol
The Toyota 1GR and 2GR engines are both the same bolt pattern. This will allow for 2nd, 3rd gen Tacoma and 1st gen FJ cruiser TDI swaps. It also allows for you guys to use the RA60F 2nd gen Tacoma 6 speed and RC62F 3rd gen Tacoma 6 speed and RA61F 1st gen FJ Cruiser 6 speed transmissions in your trucks. You will also be able to use RC60F/61F out of the 8th gen Hilux 6 speed but that means you would have to get it shipped across the pond.
To use any of these transmissions you will need a transfer case from a 2007-2014 FJ Cruiser that used to have a 6 speed manual transmission. This transfer case has the front drive shaft on the driver side which could pose a problem. All these 6 speeds have the 22 tooth spline output shaft the automatics had a different spine count. 2nd and 3rd gen Tacoma’s use electronic transfer cases.
The RC and RA bell housings are noticeably different then Toyota previous transmissions because the starter is on the drivers side, beside the TDI oil filter and they have a larger bolt pattern.
I know the RA60F is rated by Aisin for around 390lb/ft of torque, the other transmissions likely have the same rating. That’s like 250hp for our TDI’s.
This thread talks all about this
https://www.tacomaworld.com/threads/6-speed-shenanigans-ra60f-swap-to-rc62f.701237/ post #50 specifically talks about transmission compatibility.
Marlin crawler has a great page on transmission ratios
https://www.marlincrawler.com/tech/transmission/transmission-gear-ratio-chart.
Only one problem how deep are your pockets?
