passatin
Have a 97 passat tdi. Battery went bad as it failed a load test. Just replaced battery and when it is running the battery light on the cluster stays on red. Only started it and let it run for a couple minutes and turned it off. Light stayed on...
is it an alternator?
If it is the alternator then does the serpentine belt need to come off as well?
Is this a do it yourself job?
Any ideas?
thank you.
Any ideas?
thank you.
