moblemaster
The Passat drives but runs roughly due to lost compression in 3rd cylinder. Great fix-upper or parts or project car. Vehicle has GreaseCar Kit ($1,195), installation (was about $1,300). The fuel injection pump was rebuilt ($800) prior to adding kit.
Interior is in bad shape but tires, shocks, struts, starter, and battery were recently replaced before loosing compression in June of 2009. Out of work, 2 years now, and need to sell to make ends meet.....
****** Here are some pictures of the Passat ******
http://crumwaldon.com/html/Passat.html
P.S. NEVER USED KIT AFTER INITIAL INSTALL TEST RUN DUE TO A WIRING OR SOLENOID ISSUE AFTER RETURNING FROM GOOD-OIL IN LOUISVILLE,KY .
(see below)
On Wed, Sep 5, 2007 at 3:30 PM, Ethan Olmstead <Ethan@greasecar.com> wrote:
Joseph,
Here is a preliminary troubleshooting document. Let me know if you continue to experience problems. This file is for up to '95 models, but is applicable to your model as well.
-Ethan
(see below)
Joseph,
-Ethan
