Hi, so since I bought the car it had the cable for the fuel temperature cut on the injection pump and the car was smoking. Now I've fixed the cable and the fuel temperature sensor is working but it is still smoking. The problem is when I step on the gas the car when going over 3k rpm starts sometimes chooking and sometimes it dies and when I leave the gas pedal it comes back on. So here are some pictures.
This is the smoke .. idk if its white or grey I cant tell but I sure can smell the diesel when the car is on.
Here is the video https://streamable.com/8482tz
So this is the timing atm when I got the fuel temperature sensor working
This are the vcds groups when the car was in idle
This is the video when I've flored it in 2rd .. It goes to 4k rpm and the car dies so even if you hold the pedal it wont go anywhere and when I leave the pedal for a little it will get its power back ... https://www.youtube.com/shorts/Z-MOpS2a1Vk?feature=share
Here I flored it in 3rd till the end and I starts good but then loses power and cant make it any further than that https://streamable.com/7c4b2e
This is 2nd gear again when the car starts loosing power it also started hopping .. https://streamable.com/m0mfq3
So what do you guys thing is it fuel related, maf sensor or a clogged up intake manifold or exhaust or something like a turbo or wastegate ?
I will take off the egr and intake manifold today and clean it.
