TurbinePower
Bit puzzled, and working on solving an issue that's been recurring for a while now. Well, two issues really, doubtfully related.
First is the oil pressure issue, being more important. Oil pressure light is on at idle and low engine speeds. There is adequate, fresh oil of a proper weight (10w40) in the engine, so I'm guessing it's likely the oil pump, and it's too consistent and at the right times to be an electronics issue.
Can the pump be replaced with the engine in the car? Where is the pressure switch, so I can plumb a gauge in and make certain before I start pulling things apart.
The second problem is a squeal in the belt system. Fresh belt, fresh tensioner pulley: could be an idler pulley? Seems that it's also possible that there's grit in the pulleys causing the issue.
Wet conditions appear to resolve the squealing problem, and since the belt shows no signs of rubbing or slipping I really am not sure what else could be chirping. It's been described as a "crickets" sound.
I'll take what help you folks can give me on either of these!
