92 ranger swap
North carolina
2002 vw jetta tdi
so im having difficulty with the bolts on my flywheel to the crank adapter. So the bolts i pulled out of the manual truck were m10x1.0 and 45mm long. These bolts are to long and i dont want to cut them. Has anyone done a manual 92 ranger swap and know what length bolts they used. Also what grade are they 10.9? If you look up this year model flywheel bolts it comes up with a 23mm bolt which wont even reach through the flywheel.
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
I'm using ranger flywheel bolts in my tacoma swap. I cut them down and they've worked great for nearly 250k miles and 14 years.
