cumminsfromthecold
The truck is for sale. Time for the next project : ) Please PM if interested.
i bought the EcoD in Dec 2019. As a full time builder, it was a necessity, esp for towing. I’ve had 0 issues with it EXCEPT for the fuel injection pump failing. This is a recall item for which there remains no fix. In the fall of last year, I brought it to the local Dodge dealer, where, over a month, they got approval for a replacement oem pump and installed it. Not the good one forthcoming to solve the recalled bad one, just a new bad one. No costs to me except not having the truck, but the Yota got me through. It’s been a good truck. Aggressive tires, shell, heavy foot, and always carrying tools keeps mpg at 16-18. Not great. Probably sell it next year before the 10 yr/100,000 mile mark (at which point most banks won’t lend on a vehicle).Best of luck, I'm sure you'll get going smooth again.
I'm curious about your EcoDiesel thoughts. Did you buy it new and how many miles did you put on it? Any positive/negative experiences with it?
The old Toyotas are a lot of fun, but something newer wouldn't be bad...
Oh is THAT what he meant? Wow, I couldn't figure out what he meant, cap and check valve and who knows what. LolIf it was running fine, I think physical timing. (Phasing of the cam, crank, and pump) can be ruled out.
There was just another thread where someone was not getting much fuel out of his injector lines. Turns out the check valve in the pump cover on the return was stuck open. Not enough head pressure for the injectors, it was flowing back to the tank.
He said he found it by pinching his return off and fuel was pumping hard out of the injector lines. You probably should loosen all four so you don’t over pressurize them and blow your small injector return lines off.
His terminology through me off. I had to go back and read the thread, then it was clear. That was a good findOh is THAT what he meant? Wow, I couldn't figure out what he meant, cap and check valve and who knows what. Lol
Very helpful. TDI terminology matters.His terminology through me off. I had to go back and read the thread, then it was clear. That was a good find
Case pressure relief valve probably.Otherwise, what check valve?
Add the "@" sign in front of their username, like this: @AndyBeesHow do I go about linking a persons attention, Andy’s, to this thread. I see people do it often but I can’t seem to figure it out.
I doubt it, more likely the fuel return valve:Case pressure relief valve probably.
Ohhh... Ha, guess I should keep my big mouth shut, I've never even had one of these apart yet. Thanks!I doubt it, more likely the fuel return valve:
Injection Pump Fuel Return Valve (A4 ALH)
Inline valve for the fuel return line on the ALH injection pump. Referred to by Volkswagen as the air supply valve and by Bosch as the overflow valve. Normally retails for over $210....www.idparts.com
It screws into the top cover, then the banjo bolt screws into the valve.
ha sounds likely. Checking cold cranking pressure at the injectors before and after pinching the return from the IP should troubleshoot that?I doubt it, more likely the fuel return valve:
Ok so just to be clear, are you talking about this or the one P2B linked?The Check Valve (the correct name slips my mind), maintains the pressure. As I understand, the pressure does go up with higher RPMs. And, seems the internal pressure is 20 psi and above.
Thanks guys! Pinched line and turned over. No change. Plenty of fuel at injectors. Removed check valve. Sucked and blew, blew and sucked. Seemed to exercise it well enough. Timing is on. Everything is aligned. I have an intermittent glow plug relay error that clears and shouldn’t be affecting things. Wired in a fuel pump. Plenty of fuel there.Ok so just to be clear, are you talking about this or the one P2B linked?
Sounds like you're referring to the case pressure relief valve.
All true. Would the intermittent glow plug code, which has stayed cleared, cause a no start?Is that an ALH pump with a 121 pin ecu?
