84 Quantum Engine Code Location & Others...
alaskansnail
Apple Valley, CA
84 Quantum, 97 Passat
The 1.6 TD engine was rebuilt by the previous owner and I don't know where the engine code is located.
I found these numbers stamped into the block, so hopefully this helps:
IH D 2
17 1D 84
R12
The head number is:
156
068103373N
Across from this it says:
Germany
H
For some reason when I turn on the A/C the windshield wipers turn on.
My Dad said that some wires might be crossed...If that's the issue, is there a common place that they might be touching one another.
The reverse lights don't turn on.
I have checked the fuse and it's good, so I would check the bulb, but I feel like it's weird that both went out simultaneously.
