80's vintage VW Exhaust Tool $70
jjsbiggs
Nottingham,PA
Jetta 1998 white, 1997 Passat grey
I have a 80's vintage VW exhaust tool I no longer need. Hopefully someone will be able to use it. Just trying to clear out stuff from the garage. Willing to ship for the cost of shipping. There is a photo in the member album page. Thanks for looking.
The trick we used to do if we didn't have the tool available, was to put one clip on with the pipe rolled to one side, then feed an old V-belt through the other clip, then wedge a big pry bar down on the belt and lever it off the oil pan and pull that second clip down and in place, then cut the now-trapped belt off. It was a pain, but it worked (so long as you had a belt to use).
I miss the days of those much simpler cars.
To install the two clamps on the "toilet bowl" manifold/downpipe connection that VAG used on a lot of cars in the '80s and early '90s.
Vince Waldon
Edmonton AB Canada
.... the picture of which has triggered a wave of nostalgia amongst some of the VW geeks here.
T'was a simpler time... and a simpler engine. :)
