700 Mile club Who's in?
Dunno513
Mirror Lake, NH
2006 NB PD-TDI DSG
I guess I'll add my post here. 718 AUG/07 and 725 OCT/07 16.238 gal and 16.234 gal. Not quite sure how much was left, but one thing left me thinking.
If one were to push the limit to where the tank was empty and was running on fuel in the pump, lines and filter. When they filled up they would have a better average MPG for that tank, and then a worse average for the next one. Just my anal retentive mind always looking at all the angles.
lost1wing
USA, Georgia, Homerville
2003, 2003, 2002, 2000 ,2000
717 miles on 15 gals of pump diesel. 700 is pretty common driving over posted highway speeds. 750 was my best with 14.7 gals, but I was watching how fast I drove.
Fourdiesel
SW Wash. USA
'04 Touareg V10 TDI
Dunno513 said:
snip
Not really. As long as the tank is filled to EXACTLY the same level (hence the recommendation to "fill to the brim") each fillup, the first tank full CANNOT affect the results of the second.:cool:
eats1963
Saint Anne, IL
2015 Passat TDI SEL Premium
I've done it 4 times to date. 720 miles/11.6 gal; 712 miles/ 13.8 gal; 739 miles/13.8 gal; 706 miles/13.2 gal
Dunno513
Mirror Lake, NH
2006 NB PD-TDI DSG
If the tank were to be empty and the pump, lines and part of the filter, then when you filled the tank those items would just be air. After you started the car that small amount of fuel would be taken from the tank, essentially reducing the amount of fuel you put in the tank.. making fuel economy figures better that tank, and worse the next. (Its a tiny fraction, but it still exists the possiblity. Like I said.. my anal retentive mind thought of this)
Fourdiesel
SW Wash. USA
'04 Touareg V10 TDI
I stand corrected, The fuel consumption calculations DO assume the fuel lines/pump/filters contain the same amount of fuel both before and after fueling. I can't think of a way to accurately measure the fuel in the lines used just as the engine dies from lack of fuel but I would be suprised if it is more than about a half cup. (The lines/filters/pumps need not be completly dry for the engine to die - SOME fuel remains in the low spots). There are 4 cups in a quart and 4 quarts in a gallon so a half cup is about 1/32 gal. About 0.03 gal, less than the rounding error if you record fuel used to the 0.1 gal (tenths)
Tracab
Lakeville, MN
Currently Without. :(
I did it Finally!!! I am currently working on 800 miles for this tank. I think it is going to be close. Right now I am on pace for 830 so we will see.
I forgot to take a pic of the MFD of the MPG but it said 43.6 MPG and when I divided my 16.130 Gallons when I filled it was 44.3 MPG.
Who said Big, Heavy Cars cannot get good gas mileage. :)
ibanix
New Hartford, Connecticut
2002 Jetta 5spd
Finally did it: 712.7 mi out of 15.487 :eek: gallons for approx 46mpg.
This required me upshifting at 2000rpm and not driving on the freeway over 65mph except for passing.
danielttt
Florida USA
2005 Jetta Wagon GLS TDI - Graphite Blue
Best Tank Yet
I just filled up. 16.5 Gallons and 815 miles. It seems to do best at 58MPH indicated. I drive about 60 miles daily round trip to work and it's all flat driving. I try to rev to 3000 out of first and second and then slow the accelleration in the higher gears. It is a great little engine. 68000 miles with no problems.
Tracab
Lakeville, MN
800.2 Miles!!! Sweet!! I love my Passat
Well, I did it, 800.2 miles on a tank. The MFD said 46.1 MPG.
My math says the same. 17.358 Gallons of ULSD D2.
It took me a week to complete this trek at 70 miles to work each way.
I do not think I will see 800 again for a while. It is getting too cold now.
L0o0ky
Corvallis, OR
2002 Jetta TDi--sold
Finally made it--on B100 too!
Well, just had the TB done and intake cleaned (thanks oldpoopie)!
Loaded up the car for a road trip down to California. Put an extra 16 gallons of B100 in the trunk for the trip home and took off. 80% highway following posted speeds (55-70 depending on the stretch of road). Last hundred miles was hilly, twisted slow going or city stop-and-go.
Finally made it in. Had 700.3 miles and put in almost exactly 15 gallons of B100--it's hard to get an exact value when you are pouring out of fuel cans...
[edit 11/14]That 15 gallons of added fuel got me 703.4 miles on the way back[/edit]
95 avus blue
By the Hudson River, NJ
00 Jetta TDI, 01 Jetta PD130/6spd, 12 GLI, 14 CRV
Aah, finally I can post in the 700 mile club. I managed 3 days of driving, 725 miles on 15.7 gallons of BP diesel, with 1/3 botttle of sandyne. 45.97 mpg is not bad, not great either, actually it is for me considering that I was averaging between 70-80 mph.
broundtree
the bayoulands of south Louisiana
2003 Jetta GLS 5sp TDI, Reflex Silver, M1 0W40
First 700mi tank and best fuel efficiency since I've owned the car (bought it @ 52k). Could have eeked another 40-50 miles as it appears that I still had a gallon or so in the tank. Recently cleaned the intake and EGR, replaced TB and MAF. Gained 4mpg on these maintenance items alone. Just put a set of Continental ContiPros on, running them at 48psi all around. Cummulatively, all these little items add up! BTW, I run PowerService additive every other tank usually...
DieselDriver2003
Demarest, NJ
2006 New Beetle GLS 5spd
700+ miles on a tank
48 PSI? Holy cow Batman!!:eek: :eek: :eek: Seriously, I think that's bit on the high side. I run them according to the recommended pressure. I got 688 miles on a tank the other day running on something like 28 front 31 rear kind of. I now have 33 on the front, 39 for the rear. drive 60-70 but I really ripped it on the Southbound Merritt last nigh going up to 90 MPH - needless to say, a Jetta was following me, I don't think it was a TDI though, since he/she could not keep up. I was running on empty and was not a full tank so I did not care at all. This morning I filled it up, and it cost me over $45 dollars at $2.34 a gallon here in Northern NJ. I am shooting for at least 700 miles on this tank, maybe even even 750. I need to baby the car to get 750 but there are so many wreckless drivers on my way from Connecticut to New Jersey, sometimes I am forced to push it (like you're on the left lane and some idiot think it can shoehorn itself between a car in the right lane and mine). Oh, and Connecticut drivers rarely signal when changing lane.[/quote]
Darkhrse99
ABQ,NM
2000 Jetta
I'm at 705 miles with alittle less then 1/4 tank. I'm sure tomarrow' drive will trigger it to come one.
dremd
South Louisiana
06 sprinter. 03 jetta wagon premium with 6 speed ALH swap, 14 JSW
834 miles on my last tank 16.4 Gallons 50.85 mpg
75% In town
15% Highway mostly 60~65 mph
10% (first 100 milesish) driving "like an American"
Is there an 800 Mile club? I was shooting for 900, but chickened out when I saw air bubbles in the fuel line . . .. But now I see them even when the tank is nearly full . . . .
VFchicago88
Banned
pfff its been like a year since i could hit a 700 mile tank. now my car is just a POS. Making it to 600 is even a task now.
fastmvr
VA
2006 Jetta/DSG
First 50 mpg Trip
Just completed a 2000+ mile trip with my 06.5 TDI (approx 10K miles on the odo). The car has exceeded my expectations for economy. Having tracked every gallon thru the engine, overall is 45.13 mpg. For the last trip the average was 50.05, with one tankful at 50.15. The interesting thing is that the hi-mileage tank was at a near-constant 70 MPH, whereas the previous tanks were at 65 MPH. I suspect the 6th gear RPM of 2300 at 70 MPH is nearer the peak of the torque curve.
xs650
Northern California
2005 MKIV TDI Wagon
1st 700 mile tank.
2005 Jetta TDI wagon, 22,000 miles.
Just did my first ventectomied tank of fuel.
700.2 miles on 15.7 gallons for 44.6 mpg. It was mixed driving including a lot of short trips, some decent length drives and a 300 mile freeway trip over the Sierra Nevada on I 80 where I spent an hour in 10-25 mph traffic.
The gauge was centered on the red line just above the empty line when I got fuel and the low fuel light had been on for 8 miles. If the forum wisdom of 16.7 gallon capacity is right for my car, that means my light came on with about 1.2 gallons left.
I have a 1900 mile all free flowing highway trip coming up in February. That's an opportunity for a couple of 800 mile tanks.
SBAtdijetta
Houston, TX
'10 Jetta Cup 6spd, '02 Jetta Auto
Just had my first 700 mile tank!!!:D
701.6 on 14.6 Gal for 48.05 MPG. My 2nd best MPG so far, but longest tank to date.
Trip was mostly highway arround TX, only got stuck in Dallas rush hour for a little over half an hour, about 30 miles i think. Was driving 65-70mph on the trip.
TDI = :cool: lol got to love it.
onefut
Devon, UK
Shuttle 2.5 174psi
Maybe im bein naughty postin in here but ive managed 600miles in my motor
i know its not 700 but iam runnin a T5 lwb transporter shuttle 174ps
due to me haveing a weight disadvantage i am claimin it a 700miles:D I believe in racing they call it a handicap:D
Chuck_Norris
Achieved the 700 club status :D Now on to the 800 club( I think)
Driver: Chuck Norris
Miles: 705.2
Gallons: 15.632
Model year:2006
Model:Jetta
Tranny:5M
Fuel type:ULSD
MPG: 45.1125
This was my First 700 miles achievement
97pssat04golfTDIs
Rockville, Maryland USA
1997 Passat GLS TDI traded in, 2004 Golf GLS, 2004 Passat GLS Sold in Nov. 2012
Out of the 650 Auto tranny Club, now 700
I just got 717.3 on my last tank when I filled up it was 15.959 I was going to drive home from work and try to milk out some better mpg. but we have possible snow in the Washington DC area and even flurries can cause big traffic problems here. :( Most of the folks haven't driven in snow much around here, so I played it safe and filled at a local station here at work. New Nokian i3 tires I run at 45 front and 48 rear and just using the scangauge carefully is what has brought my usual mpg of 42 up to the 44.95 mpg I got on this one, not bad for a 2004 Golf Auto tranny PD. :D Now onto try for an 800 mile tank!
10leseiD
Watertown, NY
2000 Golf
I just had my light come on at 704 miles and filled up 10 miles later with 15.089 gallons and 6 oz. of PS. for a remarkable 47.25 mpg driving on winter diesel and crappy highways in NNY. highways i would set the cruise at 70 and surface rds at 60.
xmustang
Emporia, Kansas
1999.5 tdi Jetta
My question is when does your fuel light come on and do you ignore it? Mine comes on around 14.25 gallons. I drive 200 miles per day for work which my best tank was 686 miles and filled up 14 gallons.
McBrew
Annapolis, MD
2003 Golf GLS TDI, 5 speed, Silver/Grey
When your fuel light comes on, you should have 1.9 gallons left in the tank. At your 49 MPG, that's another 93 miles! I wouldn't push it that far, but I have driven 80 miles past the fuel light.
10then34
North Dakota
'06 Jetta
What type of car ?
The A5 (e.g. 06models) takes somewhere between 15.2 and 15.7Gal until empty. As the in-tank fuel pump is lubricated and cooled by the fuel around it some people advise against running it completely empty.
