Randall
That's a good point! I have a downpipe with out a CAT I should put on it!
it has been in 30s the past 3 months or so. my average trip was 2 miles ( i know it is bad for engine) and that includes 10 mins idles in morning and 1 min on the way home. 38mpg. not bad but i only got up to 42 in the summer last year. this year ill see what i get, i need to change TB and check MAF sensor.What is your highway cruising speed, & average daily journey distance (each direction)? Do you ever do short trips (for example, to the shops?) Is it still cold in your area (noting your thread where you said that you were idling for 15 minutes prior to moving off - when it's cold your mpgs won't be good).
If your average journey is only 2 miles(!!), then 42mpg in the summer is pretty good going. No point in hunting for faults if the mpg you are getting is reasonable under the circumstances. I'd have been tempted to walk it & leave the car behind.it has been in 30s the past 3 months or so. my average trip was 2 miles ( i know it is bad for engine) and that includes 10 mins idles in morning and 1 min on the way home. 38mpg. not bad but i only got up to 42 in the summer last year. this year ill see what i get, i need to change TB and check MAF sensor.
Whoa, whoa, whoa. What do you mean drive without brakes? How would LED tail lights increase fuel mileage? Also, how does rapid acceleration help mileage?To be able to get higher than 60 MPG with a 1.9 TDI you need to drive under 60 MPH or have lots of mods on the car. If you don`t want to change the fifth gear I would suggest changing the tires to 175/80R14 to front and after that set the stance correct with lowering springs.
Other things that help:
- lowering the car, more the better
- lose weight
- 0w-30 engine oil and Redline MTL to manual transmission
- Loose the brakes
- Check and adjust tyre angliments
- DRL led lights and led tail lights
- Aeromodifications as much you are willing to change your cars looks
- Remap your ECU. If you just use evry mod your fuel consumtion will increase if it is always on. Evry help on accelerations.
And most importantly hypermiling driving technigues. Rapid accelerations and drive without brakes etc...
There are many routes to 60 + MPG range depenging do you want to spend money or just drive more slower and or use more fuel efficient driving techniques or install aerodynamic improvements.
The main benefit of P&G is to avoid engine resistance....
Others have witnessed that pulse & glide acceleration and coasting improve economy. ...
