70 MPG/1100/1200 Mile Club
Blue_Hen_TDI
Slower, DE
owned: 96 B4V, 06 Golf, 12 NMS, 15 GSW
To add to that, I filled my car to brim on Monday at lunch and then parked at work about 1/4 mile away. I then topped off after work, just to see what would happen. I was able to get in 0.3 gallon after the 1/2 mile driven w/ two startups.
I have to agree that the diesel expansion worry is overblown.
Oil_Burner
Issaquah, Washington, USA
Well, last tank. 920 miles on 15 gallons even. 62.33 mpg. ZERO engine off anything. Zero coasting. Normal driving. Ive got to try some of your wierdo techniques and see what I get.:D
mrGutWrench
Carrboro, NC
'03 Jetta Wagon, 5-speed, 563K Miles (July '23)
__. Yeah, OB, I just got two tanks into the 60's (first with this '03 wagon). No wierdo techniques for me, either. But I did have a .658 5th gear put in my car in June. It sure is nice.
no_one_of_consequence
Mexico
Jetta A4 2006
miles_____gal____mpg___ date
1100.44___16.25___67.71___oct_07
1103.55___15.87___69.49___nov 07
1175.69___15.82___74.31___dec 07
1111.63___15.76___70.40___feb_08
1112.25___16.02___69.42___apr_08
1124.10___15.79___71.19___apr_08
1113.49___15.60___71.37___may 08
1103.55___15.80___69.82___jun 08
1207.13___17.51___68.94___jul 08
1109.10___16.19___68.50___sep 08
Driver: no_one_of_consequence
Miles: 1109.1
Gallons: 16.19
Model Year: 2006
Model: Jetta A4 PD
Tranny: 5M
Fuel Type: D2
MPG: 68.50
This is a pretty odd tank and turned out to be kind of disappointing considering that the reprogam should improve FE. Many things have changed since the last 1100+ tank: Unitronic 1+ reprogram, panzer plate, front tires now are Michelin Hydroedge @ 44 psi instead of Michelin Pilot @ 51 psi and oil change was a 5w40 (502.00-505.01).
The car runs better and I find difficult to stay way from the go pedal. Also, I need to go back to the 5W30 low viscosity oil I was using. Hopefully the ECU file will be fine tunned soon and also I will play a bit with the idle speed.
Most of the tank were highway miles (say 90%) and using P&G from 50 to 60 mph (70%) and some from 43 to 55 mph (30%), both using 5th gear.
Fix_Until_Broke
03 Jetta
Wow - good work (again). I think I've missed the high MPG opportunities for the year here - starting to turn cool. Might have one tank left before the cold starts really start to take effect. At least the tune has not lost you any MPG's.
BioBob
Raleigh NC
2001 Jetta (G3F Donor), 2003 Bora
Resurrection
Not much activity on this thread recently, but now that summer fuel is here, I expect that will change.
I'm still trying and have made 73.5 for 300 miles, and 75.6 for 200, but so far that 1200 mile tank has eluded me.
Was it ever decided to change the rules (i.e. 500 miles @ 70 mpg or 600 miles on the first half tank, etc.)? I know there was some discussion last fall about changing the qualifications for one of FIX's stickers.
I'd like to get a 1200 mile tank anyway, so I'll just keep trying !
Fix_Until_Broke
03 Jetta
I don't think a decision was made. My opinion is that your fillup should be >10 gallons and preferably at the same location as the initial fill. This keeps it a large enough number of gallons that measurement errors are minimized and you didn't coast down the rockies (like VW's mileage contest), but dosen't force you to go 1200 miles to make it crediable (which I'll be the first to admit is daunting).
Mexico
Jetta A4 2006
Summer Challenge
Hey Fix, what about a 200 mile round trip 77 mpg minimum challenge.
To enter you have to already got 70 mpg/1200 mile tank.
Just for fun, no other rules.
NOOC
BioBob
Raleigh NC
200 Mile Challenge
Hey N.O.O.C.:
Do we have to re-fuel at the same station (i.e. run a loop rather than a straight line)?
We know Ernie can do around 90 if he can straight line it. and I think I can get around 80 coming down I-77 (with a North Wind blowing)
Mexico
Jetta A4 2006
NOOC
Running a loop would be ideal to avoid tailwinds and endless powerless downhill glides.
Fix_Until_Broke
03 Jetta
NOOC
That's only about 2.5 gallons, but is doable in a half day or so which makes it appealing. I might have a couple ~100 mile trips to make alone later in June that I could make an attempt at it.
I can tell you right now that I won't be competitive at all - Need to make some changes on my car just to get back to where I used to be, not to mention improve upon it. I've still got a few ideas up my sleeve though :)
BioBob - I think that filling at the same location is a pretty significant factor because it minimizes so many variables (elevation, fill up variances are minimized, winds are minimized, etc). I think if you were to make it to 1100/1200 miles though the fill location becomes less of a factor, but on something as short at NooC has proposed, measurement variables become much more significant.
Digital Corpus
Ontario, California
'97 B4 w/ 236K mi body, 46K mi soul
I just did 1088.6 miles on my last tank. I Think that with a little more slow down I can get a 1100 mile tank out of my B4. This would require a smooth 56+ mpg driving at about 55 mph. I'll post back in 3 weeks when I fill up!
Digital Corpus
Ontario, California
Looks like few people are trying to achieve status in this thread. Well I'm happy to put my name on the 1100 mile list with 1100.4 miles and 19.25 gallons!
apaterso
Livermore, CA
Jetta 2009
rvinvents said:
ho do you guys get so many mpg's the best i can get is 38 mpg what is wrong?
Just an educated guess, you have a 2009 or 2010 TDI. Thus low mileage and heavy emission equipement. As so I. If you will notice the people getting huge MPG have dirty diesel older TDIs. It seems that the clean diesel TDIs get less mpg.
stuckless
florida
2009 Jetta black automatic
You are correct here. The 2009 and 2010 will not get you as good MPG as the dirty older diesels. In normal highway driving which is 65-75 mph your lucky to get 45 mpg. If you drive like granny going 45-55mph yes you might get over 50 mpg but unless you have an older Jetta TDI anything else is just plain BS.
andyjh
Peterlee, England
Passat TDi
I'm lucky if I could get 600 to a full tank :eek:
B5, Jammed Turbo Vanes, Boost Leak, Clogged Manifold and Faulty MAF I'm guessing :D
Can't get the VNT to move under 30 inch of vacuum so the vanes are well and truly stuck cos it cycles fine with vag-com lol
Cars hibernating until January now. I'll fix it when it's warmer :)
jcfone
ohio,usa
2000 jetta tdi alh
Imnew here but all this is awesome I really havent pushed any limits since my car was new 2000 jetta alh. I do boast of 44.1mpg delivering pizzas w/air on never shutting car off look forward to more fun when I get my wife a new car
HoneyBeetle
Massachusetts
2001 VW NB TDI
I wanna do this too! How do I get this kind of mileage? I'm hypermiling and coasting all over the place. I'm not sure I can do much better unless I dump the spare and loose about 20 lbs of body fat....lol! What to do? Does running on B20 REALLY make a difference?
MikeMars
UK
Vento 1.9 TDi (retired), A4 1.9 TDi (rear end collision), VW Passat 1.9 TDi (retired), Audi A2 1.4 TDi
Bumping thread. It's a good one and it's a pity to have it fade in memory.
smck
south east indiana
2000 golf man, 2003 golf man
I'm in the club, but still trying to catch these guys with 1200+ on a tank. Hopefully I get my car back on the road this week with new (to me) 6sp from ryanp.
Turbospool
Daleville Va
2001 White TDI Jetta, 280k, 2003 jetta 270k
hey smck let us know how she goes with that new 6 sp tranny.... why did you change it? :confused:
Turbospool
Daleville Va
Well today I joined the ranks ...... got my first ever 70.79 mpg tank. 716.4 miles filled diesel up into filler neck to run out point with 10.02 gallons. I simply couldn't believe it :D . Did this on my daily commute to work. I recently tweeked my timing via vagcom in adaption to 4.5 advanced and it seems to have pushed me over the edge. :)
