60+ days in the shop, still no diagnosis
Stafford Virginia 22556
96 glx variant tdi
The "d" suffix is the cold weather upgrade used to mitigate the check valve gelling. At least he got that right, although that part still doesn't have a pump in it. Of course, charging $380 for a $100 part is a bit much though.
Rrusse11
PA Deutsch Country
2002 Golf, 5spd; 05 Jeep CRD
Well cowgirl,
You're clearly being taken for a long and expensive ride. And your ride still doesn't work.
Pull the plug if you can, you really need an honest mechanic/guru, sadly in short supply.
My condolences, waaaay too far away to be of any help personally. At least you've found
this forum, it's a good start. Grit your teeth and keep on asking questions, you ARE
getting straight answers here.
All the best!
gearheadgrrrl
Buffalo Ridge (southwest Minnesota)
'15 Golf DSG, '13 JSW DSG surrendered to VW, '03 Golf 2 door manual
Sounds like even the VW dealer techs can't fix VWs in your area, so if you keep the car your only choice is to fix it yourself. Buy a manual and decent tools if you don't have them already, and get parts from a trusted supplier like ID Parts or a VW dealer. If you get stumped or just need advice ask here, there's so real TDI experts on this list and they freely share their hard earned knowledge. I've been on this forum for around 20 years now and the folks here have helped me keep 3 TDIs running for over 250,000 Miles.
Tdijarhead
Lawrenceville PA
Gearheadgrrrl is correct, I seem to remember several years ago she did her own cam replacement or head replacement, I don’t remember right off, but I do remember her tackling some kind of major job like that and accomplishing the task and keeping her car on the road, I was impressed.
Tdijarhead
Lawrenceville PA
Haven't had to open a TDI engine up yet, but with the help of a manual and the good advice here I was able to DIY the timing belt, brake jobs, shocks & struts, etc..
I was thinking you did a cam several years ago. It must have been another of our lady members.
Even doing a timing belt is no small task and something to be proud of.
csstevej
north nj
Congrats on accomplishing that……
tdidieselbobny
Stafford,NY (WNY)
'03 Galactic Blue Jetta TDI, '15 Silk Blue Golf Sportwagen TDI
I truly wish one of the veteran West Coast members would help this poor lady out. Truly disgusting that it seems to be she's been screwed over on car work time and again because she's female. I'm just wondering if one of the fuel lines coming from sender to front of car has a crack somewhere. Don't those lines have a check valve somewhere?
csstevej
north nj
If it hasn’t been drilled out it’s on the fuel sender unit
Shenandoah
Shenandoah Valley, VA
2005 Jetta Wagon; 2005 Beetle; 2004 Jetta; 2002 Golf (three of them); 2002 Jetta Wagon; 2000 Audi TT->TDI; 1999 Beetle
I'm not sure I'm following everything on this thread? A couple of things don't seem right:
1) If a gas fuel pump was installed and wired to power the pump (if it was a gas unit), the pressure to the injection pump is too high. An ALH only has two wires for the fuel level sending unit. A BEW/BRM has four wires (two for the fuel level, two for the lift pump)
2) I read that the fuel lines were cut when the fuel level sending unit was replaced? How did they "splice" the fuel lines to connect to the new fuel level sending unit? I would start with those "splices" for air in the system.
3) It's your car. The mechanic/dealer can't keep it if you want it back.
Eric
Tdijarhead
Lawrenceville PA
I think the mechanic put the correct sending unit in and called it a lift pump, maybe to justify the $300+ price tag
csstevej
north nj
Depending on where you bought it yes….I looked real quick around….. cheapest I saw was $65.00 with vw p/n‘s on the pump. The highest was $285.00. So with a mark up it’s conceivable….not right….. but conceivable…..
csstevej
north nj
So what was done to it now?
STDOUBT
Portland, effing Oregon
dos jettas
It's still not fixed.
cowgirl, peterdaniel is only 400 miles north of you, straight shot up the coast. You should PM him IMO.
cowgirl007
Santa Ana, CA
2003 Jetta GL 143k miles Original Owner
He took it apart and checked the entire system for leaks. It's still getting air into the system but apparently it was stalling out while running because the leak was so bad. He says it's getting less air now and he ran it for an hour. He spent 2 days testing for leaks, replaced some of the hoses, replaced an o ring on the new fuel sending unit and now he's leaving it to sit overnight to see if it still has a rough start tomorrow. He seems pretty confident in the injection pump reseal he did but he says it seems to be getting air into the system or losing pressure from the tank. Something like that.
Nero Morg
OR
Sounds like it's time to find a new mechanic
Tdijarhead
Lawrenceville PA
IF...he is confident in the reseal and IF he did get that right, one of the primary culprits for air getting into the fuel lines is the T on top of the fuel filter. They are plastic and can crack or there are two O rings on them one or both of which can get pinched and not seal properly.
Genesis
Sevier County TN
'03 Jetta Wagon
I've also had a filter that was out-of-spec (slightly out-of-round hole into which the "T" goes!) that appeared to be fine when first installed but quite-quickly proved to be a serious air infiltration problem that (obviously) couldn't be fixed with new O-rings on the "T". Once I figured out what was going on replacing the filter stopped it instantly, of course.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Call your insurance company, let them know that last day you drove the car. Ask for a refund.
3 mechanics, plus current $1000+. Best practice is to find an honest, competent mechanic and trust them.
I would file some complaints with BBB. What did dealer diagnosis report?I'm guessing "new fuel pump" was just a fuel sending unit, otherwise that's gross malpractice.
Johhny04
Markham, Ontario
2003 Jetta TDi
As mentioned by Tdijarhead and Genesis, look at the 'Mickey Mouse' T connection top of fuel filter to see if cracked or allowing air into system.
cowgirl007
Santa Ana, CA
As of this morning, he says the air leak seems to be coming from the tank so he's taking it out and looking for hairline cracks. He also ordered a new sending unit to test and see if that is causing problems.
Mozambiquer
Versailles Missouri
A crack in the tank will NOT cause air to be pulled in. That is complete baloney! He's lying through the teeth and is just sucking money from you. You need to report him to the BBB.
CleverUserName
NorCal
2014 OZ Cruze CTD & 2010 JSW 6MT & 2017 GMC Canyon CCLB ATX 2.8 Duramax
It's gotta be leaking from the lines, connections, fittings or the pump itself. Air is a smaller molecule than diesel so you wont see any telltale fuel drips but it can still let air in if there is a crack or loose fitting.
BobnOH
not-a-mechanic
central Ohio
I'm too confused and flabbergasted to enough offer advice on repair.
What was the original complaint?
Hard to believe an '03 with that few miles has much wrong with it. Unless of course it's been totally mistreated, which I doubt.
Diesel Fumes
Creston, bc
2003 alh tdi 5 speed
Yea it's quite amazing. I've owned clapped out tdis with like 400k miles on mostly original parts, leaking and burning oil, etc. Yet they still start and run fine. And when there is an issue I pay a generic mechanic a couple hours worth of his time to fix things up and off I go. And this is an extreme climate which I think is harder on everything especially fuel lines, hoses etc getting salt and dirt on them half the year and freezing temps the other half of the year.
Its unfortunate for the original poster. These cars are not difficult to keep running though it definitely helps to have a basic understanding of how the car works. It sounds like she's being taken for a ride.
