danielhf
(Sorry for all the pictures to those of you on dial-up)
Before:
After:
I can't believe I am finally posting this. After many different engine-related issues with my ALH, it became abundantly clear that the most cost-effective solution to fixing my motor was to just put a new one in. Last winter/spring I purchased a complete donor PD150 Golf (in the UK) as well as a spare short block, complete head, bare head, extra TDI 6 speed, and some miscellaneous other odds and ends.
PD injection seemed advantageous to VE for two reasons:
PD motors do not have the same fueling issues that one encounters with the VE system due to the lack of an injection pump to worry about matching to high-flowing nozzles. With larger nozzles, the PD will easily flow just about any amount of fuel I need. The other reason why this swap made so much sense was that I have been planning a stand-alone 4motion swap, and I needed the guts from a FWD TDI 02M. It was very convenient that my new motor would come with the transmission that I needed.
I purchased a Audi TT AWD 02M (code FHB) with transfer case to put the gearing from the FWD TDI 02M in. I was planning on building the AWD transmission and installing it before the conversion to AWD as to avoid having to buy both a FWD and then later an AWD limited slip differential (the R32 LSD has a splined output) (after having one in my 02J, I don't think I could live without it). While the transmission was open, we took the opportunity to replace the pins and rivets holding the shift forks to the shafts with M8 bolts (good thing we had spare bolts from the EGR cooler) that were either welded or Lock-Tited (if the outside surface was the brass from the shift fork itself).
Before:
After:
