J.P.
- Joined
- Aug 14, 2007
- Location
- Northern MI
- TDI
- Black 05 b5.5V/6spd w/274k miles (daily). Silver 02 Golf/5spd w/240k miles (fun 1). Mint Tornado Red 01 Golf/5spd w/440k (ALH still perfect!!!).
My 6 speed shifter tends to "catch" going into 2nd. The best way I can describe it is when I'm shifting into 2nd from 1st or 3rd, when the lever gets to neutral, it moves a little to the left towards the reverse position and gets hung up. It won't continue down into 2nd unless I physically slide it over to the right a little, and then down into 2nd. I'm not sure if it is an adjustment issue, or a worn parts issue. I did a quick inspection of the pivot and linkage components and they don't seem terrible.
2 things:
Is there a really good resource for adjusting the shifter and linkage?
For a rebuild, where are you sourcing your parts? It looks like the pivot ball joint has been discontinued :-( Where are you getting replacements?
Anybody using the aftermarket shifters like 034 Motor Sports, or JHM? They are spendy, are they worth it?
2 things:
