david_594
Edit: The important details.... A .70 and a .681 fifth gear sets that should fit the stock 5 speed manual tranny with the TDI were found. The .70 was never tested by anyone and I installed the .681. So now there are both a .681 and a .717 5th gear set that are verified to fit the 02J transmissions of our cars. The .717 provides a 5% reduction in RPM's while the .681 provides an 11% drop in RPM's. Either swap will provide for a much more pleasant highway experience. Rough estimates on the fuel economy savings from either swap is guestimated to be roughly half the drop in RPM's but this is not thourghly verified. If your intersted in doing this swap please read through the rest of the thread.
dave
Original stuff....
The info on the .681 gear is in my last post down this page somewhere.
So its a topic that seemed pretty popular 5 years ago and myself and another club member were considering it a bunch as of lately and found some new information. First off the ALH tranny comes with a .756 5th gear set and the original upgrade was to swap it out for a .717 from older diesel AAZ engined diesel available in canada. This provided an RPM drop of rough 5.16% and the people who did it claimed a small increase in fuel economy. In the old threads on this subject there was mention a few times of a .681 gear set from an Audi which would have provided roughly a 9.92% drop in RPMs, but no one ever provided what vehicle or tranny this was from so for as much as anyone knows it doest exist.
The new news
Doing some searchign, supposidly the new 100hp BEW PD's come with a .74 5th gear ratio with 29/39 teeth. This seems fitting with the added HP of the newer 100hp PD motor. (I got this info from a VW tech who looked it up at work)
Also, a .70 5th gear set(28/40 teeth) was found from a euro eurovan 02A tranny. From whate I have gathered the gears from the 02A and 02J are interchangable so this should be a feasable upgrade for all our A4 TDI's. This would provide a roughly 7.41% drop in RPMs for an ALH tdi or 5.41% drop in RPM's for a PD.
Here are the part numbersfor the .70 eurovan gears.
02A 311 361 AM
02A 311 158 AF
So who wants to be the guina pig? This wont be cheap, probabily somewhere close to $400 as the parts would have to be shipped from europe. But at the same time if you get your original gears out in one piece you should be able to sell them to a gasser for around $150 to recoup some of the cost as our gears is an even larger upgrade for them.
Here is a link to the how-to hosted on the tdiclub pictures server:
Follow the link, login to the pics server, scroll down and click on the image that says "multimedia" and it should download the PDF for you.
Please ignore the numerous typos as I clearly didnt proof read it when I made it. Also take the warnings seriously. When I first wrote this up ~10% of people had major complications when doing this mod.
dave
Original stuff....
The new news
02A 311 361 AM
02A 311 158 AF
