I will likely do just that. I was hoping to be able to tow a little bit with the car but it sounds like 60 additional HP comes at a pretty high cost. I'll bet they could have engineered it into the car at about the same cost as it is now... but I also understand they were fighting emissions and of course reliability was a concern. I'll likely just keep it to really light loads when I do tow and hopefully the 90hp will do it.If you are pinching pennies, leave it stock. It will cost you less. These cars are very good just as they left the factory. Let your budget keep it in good working order as it already is first.
Whilst possible, I think I'd prefer not to saddle a VNT15 with a 150 hp load.1) injectors
2) evry mod
3) nitrous
done
You're probably right. I'd think without an EGT gauge, the smoke level's I've seen in videos, may not be such a safe bet. Maybe with the lower end of the mod (maybe 1k resistor).Just as a suggestion, don't do the evry mod, unless you want to break things.
In that thread, I think I also read he used the stock 10mm pump and someone asked him about using an 11mm and he said, not necessary.he just said 1) 150 hp and 2) $500
not "the best way for a daily driver" or "and maintain best fuel economy" or any other conditions like "and not blow up my car"
just $500 and 150 hp.
Gary Miyakawa did that back in 2002, nearly 20 years ago. Upsolute chip, but same difference, may as well use evry mod.
New Performance horizons....
For those of you who were at the Fest, you all know about some of what I have done to acheive my 15.592@90.37 1/4 mile times and I was nearly .5 seconds faster than the next car (Joe O).... for those who weren't there... There has been a discussion on this (and other) boards for a long time...forums.tdiclub.com
you seem to be forgetting that diesels are throttled by going leanI've got it. Attach the nitrous tank to your drivers side fender then run a hose to the intake with a electric valve running off the gas pedal. More air, more fuel, more nitrous! Win/win as you can see with my soon to be patented set up.
But more fuel more power.... isn't that why you get bigger nozzles for more power? The more stuff you have going into that cylinder the higher compression you get too.you seem to be forgetting that diesels are throttled by going lean
meaning that you only jet your nitrous system down in order to avoid wasting expensive n2o, excess that doesn't find any fuel to burn just goes out the exhaust, same as excess oxygen does at any other time
no need to overcomplicate it
as an aside, inchville's idea is... typical of his ideas (need I say more?)
The 150hp are even possible with series components from Alh. But then everything runs to the limit. A larger charge air cooling would be good.Is this possible? I don't mind shopping junk yards for parts and DIY-ing the work. I have a stock engine with a 5 speed with an upgraded clutch.
I've wondered sometimes about using the tubular manifold from an AEG 2.0 gasoline motor (they're a tri-Y style header that looks like it'd flow real good) to get rid of the horrific backpressure issues, as floating your exhaust valves is really easyOr like Kerma said, just do used Nitrous and propane for wet shot enrichment.
I've beat 300hp muscle cars with a 70hp stock 1983 Scirocco. My stock 2002 TDI is much faster STOCK than the Scirocco. I live out in the country and I've dusted the Man's new Chargers. Steering with power only works for rear wheel drive. Keep it stock, put your $ in tires & suspension upgradesIf you are pinching pennies, leave it stock. It will cost you less. These cars are very good just as they left the factory. Let your budget keep it in good working order as it already is first.
$500 budget is pretty tight for conventional power adders BUT I wonder if somehow buying a nitrous system (used can be fairly cheap) and plumbing in some pressurized / atomized diesel into the air intake stream just in front of the intake would do the trick ? (separate diesel tank under pressure to make a mix of vaporized diesel and nitrous flowing into the air intake manifold like in gasoline applications except in diesel)?.
With the above ..... no need for bigger turbos, injectors, intercoolers etc.... and capable of ADDING in excess of 150 HP so be careful !
Andrew
draw through turbocharger guys have something to say about thatYou want finely atomized diesel and nitrous oxide fog under 18psi at around 200f in your intake tract? That's a rolling bomb with a short fuse.
Please note that @[486] was jesting here. Please don't do this, unless you want to be "golden" (which I'd translate to "with a dead car and $250-$300 less money to your name").chinese ".30" nozzles
chinese mpps cable to fix the maps
chinese t25 manifold
junkyard saab td04hl-15t-5cm
prolly $250-300
throw in a bare timing belt (maybe a water pump too) and you're golden
