dogdots
I started my first B5.5 5 speed manual conversion yesterday at 8 am. Everything went very smooth (almost too smooth...) until the mechanicals were wrapped up at about 6 pm. When it was time to bleed the clutch, I had difficulty with the pedal sticking to the floor and lots of air kept coming out when trying to vacuum bleed it.
I decided to pressure bleed it, and lots more air came out, then the fluid ran clear and bubble free
and the clutch engagement felt right.
I was finishing the interior reassembly when I noticed I had a drivers side floorboard full of brake fluid
The clutch master cylinder is leaking
I pinched off the supply line from the reservoir so the leak would stop and cleaned up the floor of the car.
I still need to recode the car with VCDS and get it tuned. I did get the reverse lights operational and I modified my relay 53 so the car will start until I get my clutch switches wired in.
All in all the swap went very well short of the defective clutch master. I'll be excited to get that swapped and finish the wiring and tuning next weekend when I get back from day job travels
