Around 2 years ago, I changed the gearbox oil on my tdi, I bought 2 liters of it (febi bilstein 21829 75w), I also removed one of the pivot pins and drained some more as indicated on the workshop manual.
Since then, the gearbox has been leaking on that pivot pin and on the vw cap which I didn't touch.
In the meantime I've read that the pivot pin o-ring (N90362001) should be changed, which explains why it's leaking, I didn't change it.
Yesterday, I drained the oil to put some teflon tape on the drain plug since it's also leaking and measured 1,2L of oil that came out. I didn't take the pivot pin because I don't have the o-ring yet.
Now here's my problem, I decided to fill the leftover from the bottle I had because why not (600ml) and the rest with the oil I just drained (600ml more). As I was reaching the 1L I looked below and it was already leaking all over the place, made a mess on the floor.
I don't get it why did this happen, the car was level, the gearbox was not overfilled before, I've checked 2 times the oil level in the past months and it was right by the lower edge of the fill hole. I ended up jacking the side and put the 200ml more. The manual doesn't mention the gearbox being tilted and having to fill through the reverse sensor, the correct level should be by the lower edge for my car.
I'm really struggling to remember (no sh** sherlock) how much I drained when I did the change but judging from the leftover I atleast filled 1.4L.
Since the manual says the gearbox takes 2l I don't understand why I only put 1.4l at the time but I'm sure I didn't drain the full 2l either. I guess that's the capacity when the gearbox is rebuild as I checked the A04 5 speed which should be similar and it says 1.9l rebuild, 1.7l oil change.
To sum up, as I don't really know how much oil there is in the gearbox, can I drain it again including taking off the pivot pin and fill atleast 1.7l ? As I think I've been driving with low oil ever since although it was at the lower edge. Is there a risk of overfilling ?
