450 mile tank
Mongler98
COLORADO (SE of Denver)
too much toe in will KILL your MPG by at least 5..... ive seen worse tire wear get better though.
how many miles did you get out of those tires?
GlowBugTDI
Cambridge, MN
You don't wanna know....
They're over 5 years old and were starting to dryrot/crack. Had about 40-45% tread and I've put about 10,000-11,000mi on them. There blizzaks (spelling maybe correct)
GlowBugTDI
Cambridge, MN
Ive got wayyy more miles on my all season tires which I've ran year round the last few years, and they still have pretty good tread 25-30%
GlowBugTDI
Cambridge, MN
Running a new tank, and am driving nice as what ive done anytime, and from what I've read about hypermiling in the past. Tomorrow I'll know for sure how i did. So far first 1/4 tank has gotten me 125mi. Which still sucks, but we'll see. I have driven like an egg under the pedal, and kept rpms 2-3k for shifting through gears. Speed about 60-70 for the most part, and mostly highway. Tomorrow I'll be making a 140mi round trip (all highway) for work and will see what my numbers are. Still thinking im coming in under 40mpg😕.
I really only want my mpg for long road trips, so I'm practicing trying to get high number tanks so that i know how. Then when i want good tanks i can get them, problem is i feel like I'm trying to, and still not seeing gains. I'm even coasting into stops sometimes.
turbodieseldyke
Free Mustache Rides
Big ol' honkin' tdis
Damn. If i drive my 06 hard, my needle will hit "F" at 125 instead of 145mi. The problem is your car, not your driving style.
GlowBugTDI
Cambridge, MN
So after putting on another 140 highway miles driving 65-75 i am getting the same. So I'm starting to find it doesn't matter to much how nice i drive...
GlowBugTDI
Cambridge, MN
I do have a malone stage 3 and pp520's (professionally done), but still seems a bit low. Could my flow rate be high without smoking? Im confused at this point
Accidentally reset my milage at 51.3 so about 300 miles so far😕.
The car isn't smokey unless i peg it then it will sometimes, but still shouldn't effect my milage that much.
Previous owner (member) was getting about 48-50mpg, he was at like 680 somethingish miles a tank
GlowBugTDI
Cambridge, MN
Its just so weird. Car starts great, drives great, and stops great. Still not making sense to me. I do have one break that squeaked a bit today when i let off the brakes, so im going to do the pins all way aroud, but it's not pulling to ine side or the other. Something else is not right but idk what. I didn't always get great milage in my other beetle, but i drove it pretty hard. Still got at least 480 mile tanks if not more
jmodge
Greenville, MI the winter water wonderland
More than I need, less than I want
Before you spend money and time on your brakes, go get an IR gun for $15-$25. Check the temps of your brakes after your run it. They should be within 10-15° of one another all the way around. You will find that gun will come in handy. I pull the 9v battery out when I don’t use it. I can’t tell you how old the batteries and it still works. Cheap in handy tool
Something, or some things, are seriously wrong with this car. The only times I've seen FE drop that low is on a race track. It's very difficult to imagine that the engine seems to run normally while using that much fuel, unless you have a significant leak somewhere.
What fault codes do you have? If you can't isolate an obvious issue like a clogged intake, boost leak, streaming injector, all brakes dragging significantly, timing way off, etc., then I'd start with fuel delivery, MAF, and boost logs, and also a compression test. And also check mechanical timing, of course. At least that would be a starting point. I would imagine the issue will show itself.
TurboABA
Kitchener, ON
Maybe he's got no wheel bearings.... or always driving uphill.... or actually is in La Rinconada, Peru, instead of his listed location.... :unsure:
Mozambiquer
Versailles Missouri
Do you have vcds? If so, check the TDI timing, also check the lph fuel usage at idle and maf specified vs actual.
If you don't have vcds, get it, it will really help you out.
GlowBugTDI
Cambridge, MN
Ya, sounds right to me.
No egr code, and seat belt lock (in the clicker part) code. No limp mode boost leak, will look for draining fuel. Intake cleaned this last summer when i did the egr delete. Car slows normal, and doesn't pull but I'll check that. I don't have vcds, but a local guru does if i can't find the problem ill send it to him. MAF was new last summer, could check anyway though. I could check compression too, but its low miles...
GlowBugTDI
Cambridge, MN
Nope bearings are good. Even my local guru said last fall that the car seemed good, and drove great minus a slight vibration coming from the axle. I didn't really look at my FE though until lately....was having to much fun driving. Nope totally an MN'er. Atvs in the summer and sleds in the winter!
Something you guys should know a lot about lol
GlowBugTDI
Cambridge, MN
Nope, people keep telling me to get that...
I probably should. Idk how to use it though, and i can have GreenGeeker in town look at it. I'll look for obvious things, but if i can't find anything i may just send it to him for a couple days. Even at 20yrs when it comes to computer things like that in a car im not really sure what im doing though i could probably learn.
These engines are pretty simple. Think about fuel, boost, and timing. If you consider compression a component of boost (overall cylinder pressure made by a combination of squish and forced induction), then it's most likely one of these three things is enough amiss to cause you to use almost twice as much fuel as you should be.
Sounds like you have a pretty good handle on what's not wrong. But you've not yet located what is. This isn't a minor problem, so it shouldn't be that hard to find.
Mozambiquer
Versailles Missouri
Yeah, probably would be a good idea.
I've got an extra unlimited vin dongle I'd let go for less than the ross-tech price for their 3 vin setup. Send me a PM if interested.
There's a lot of info on how to use vcds on the ross-tech website. I used to be in the same boat as you, not knowing or understanding the computer systems on vehicles, but I've been learning, and am pretty confident with vcds and a bunch of other software, as I use Cummins insight, Ford IDS, Detroit diagnostic link, as well as several other brands including international, volvo, mack, isuzu,...
GlowBugTDI
Cambridge, MN
I'll think about it for a bit. I'll message you i decide i need it
GlowBugTDI
Cambridge, MN
So far as i can tell i want to think its fuel related. Boost problem thats causing this would make me think limp mode, unless its boosting oddly. It has tons of power and torque. I'll look at it some, and get in touch with a local guru about bringing it in if need be. I'll let y'all know what i find
GlowBugTDI
Cambridge, MN
Thank you all for giving me a good head start of what to look into!
jmodge
How many rpm's can you get out of it in 3rd and 4th gear? With your setup if you punch that in 2nd gear at about 1700rpm your tires should spin enough that you have to backpedal. Just wondering if you have driven another car and know what that setup should do. Maybe have someone follow you and hammer it through the gears, I would think there has to be smoke. That's a lot of fuel. VCDS is necessary to go any further. Boost and MAF can be compared specified to actual. Coolant temp, IQ, timing, and fuel consumption can all be checked.
GlowBugTDI
Cambridge, MN
4k maybe. Idk I'll check in a couple minutes. In 2nd itll squeel them if i clutch it right. Otherwise only squeal in 1st.
Ya it smokes, but only hazzy (at a certain rpm, then stops) from the rear view mirror. Every now and then it'll bealch (kind of odd), but thats not often.
GlowBugTDI
Cambridge, MN
GlowBugTDI
Cambridge, MN
Checked and power seems kick in at 1800-2000rpm which seems normal. Tires don't break loose like you say they should Jmodge, but idk if thats a big deal or not. If i get it rolling in first everything from there out i can peg to the floor without losing grip. Got about an 8sec 0-60
