brads
- Joined
- Aug 6, 1999
- Location
- Los Angeles
- TDI
- 2010 Golf TDI 6sp W/Euro GTD-LED tails Neuspeed flash + VCDS Mods
I have a 2010 golf TDI and now I noticed leaking of coolant on the garage floor for the 3rd time.
The last two times they covered it and just replaced the radiator but both times said there was a pinhole leak in the radiator which they had never seen before. This time they said It wasn't covered and that it would be $950 for a new one with labor etc. I topped up the car with water and brought it home just down the road. I ordered a radiator from my local supply shop for $200. When I removed the fan and radiator from the car I noticed what looked like someone had ground a tiny little hole in one of the veins of the radiator. I looked at the matching area where the fans mate up with the back of the radiator and sure enough there is a little metal clip that was all worn off and chafing the fin on the radiator. This I guess was caused by a little more vibration than normal / normal diesel vibration. When I took off the radiator and looked at it carefully, one of the supports for the fans stuck out more than all the others and this was the support with the clip on it that was worn and had been chafing the vein on the radiator. I cut and sanded down the fan support that was high and removed the metal clip, put the stuff back together, put in the coolant and fired it up. I took some pics of this.
Anybody else have a failed radiator or am I the only one so far?
this is bull****, they could have kept this from happening a second and third time now by using some common sense. I can also see where they cut back the wire when they removed the fan to see if it had been chafed too.
Dealers are aceholes. Their mechanics on the other hand or mostly cool and this guy told me how to do the radiator job myself and safe mucho dinero but this should have been covered.
I don't know if this may be a hidden issue for others out there or what but can plainly see that the design is too close and doesn't allow for movement or vibration in this area. I'll take the fans back out in 6 months and see if there is any more wear going on before I'm convinced and relieved that this fixed it.
Good luck
This image is of the chafed vein on the radiator
this image is the high area that was rubbing on the radiator, you can see where I have started notching it out and eventually sanded it smooth, you can also see the clip that was rubbing in this and the next photo.
Good luck
