bencarr23 said:
And majesty78 you are an idiot. To say something is imposible when you have nothing to base that on. how can you know have you put this turbo on an engine with all my mods then hit it with N2O?? If not keep you omposible talk to your self.
And you dont need 4 bar of boost with a 150 shot of N2O. try to remember the N2O carried alot more oxygen then air does.
Thank you for the 'idiot', In other forums you would get a warning or even banned for that...
Anyway, you may not have realized that i didnt state anything against you what is meant personal against you, but getting personal is a very common behavior of people running out of technical knowledge.
To the topic:
Yes, i know people running Gt1856v turbos, and as a little bonus, i do not only know people running them, i build them.
For the fuel thing: approx. 25percent flow over stock ARL injectors are the numbers which BOSIO gave, i guess if as manufacturer will know best.
These numbers are profen by several tuners and users here, like vwmikel said: you need only 30 degrees of duration instead of 40 for same torque, which is about 25percent less.
In that calculation you also have to take case of the way better combustion efficiency with less duration, so you gain a lot from that fact too.
Just take a look, which effort people have to take to make an engine as strong as your dynos show. (Marek, aka Stingray per example with their Lupo)
And then you come up on here an doing the same with a kiddy turbo, way to small nozzles and you even talk about 400hp which you could have done...
Everybody may think what he likes, but to me this is far beyond...
Regards, Alex
