OlyTDI
07/03 Update:
Well I’m not sure how to proceed from here. To recap:
Engine off, cabin blower on, AC on = both fans work.
Engine on, cabin blower on, AC on = S180 (30A) fuse blows immediately upon switching on AC.
Engine on, cabin blower on, AC on, compressor coil harness disconnected = S180 (30A) fuse blows immediately upon switching on AC.
The (red) wire that leaves that S180 (30A) fuse slot location goes directly to the Coolant Fan Control (FC) Thermal Switch (F18 if looking at Bentley). That switch is mounted in the radiator and has three wires that plug-in to it. I tested for continuity between where the red wire exits the S180 fuse and where it goes into the Coolant Fan Control (FC) Thermal Switch plug connector and there was continuity without resistance or any anomalies when vigorously moving the harness around.
I’m not sure how to further test as I don’t know where that red wire circuit from S180 goes from there. Can a coolant thermal switch short? If yes, why only with the engine running?
What seems like the most important clue is that the fuse blows only when the engine IS running (blower/AC on) but not when the engine is NOT running (blower/AC on).
My battery, battery box, ductwork, is all pulled out and am reluctant to put it all back together without fixing this first. Hoping for a breakthrough! Thanks all for helping and please keep forwarding your ideas and suggestions! Not sure where to go from here.
