Fix_Until_Broke
Hey - no problemgreengeeker said:Sorry...didn't mean to come off that way. It's just that I get impatient sometimes.![]()
So, what do you think of it? Good? Bad? Different? Be Honest
[Off topic] I wish I knew?DPM said:What's with the visible smoke at idle?
It's cause its a cold engine.DPM said:What's with the visible smoke at idle?
The larger the exhaust the more power it will make. It might suffer on the low end, but with the torque we have that is not a big deal.DieselSmoker said:I'm sorry to go against the grain and dont mean personal offense to the poster, but this is the riciest TDI mod I've seen yet. There is absolutely no need for such big piping, what a royal waste of time.
What data do you have to back-up that claim?devonutopia said:But 2.25" will be fine for the biggest turbo the 1.9 can handle. I should know as it's currently bolted to my car outside. Not taking anything away from the mod as it's some decent work, but there's little need to go above 2.5" even when going for 300hp.
You can't see it in the video but I installed a 3" flex joint - just like the OEM one but in 3" stainless steel. Unfortunately it's only 6" long so it's L/D ratio is worse than the OEM one that is ~8" long but 2.25" dia so it's not as floppy. I think if it were solid (no flex pipe) it would break the turbo or manifold in short order as much as the engine moves around.greengeeker said:FUB...I can't remember (can't watch the vid at work) but if you did remove the flexpipe, your work is cut out for you to eliminate the vibration issues in the muffler. If you look around you should be able to find a 3" automotive flexpipe to throw in before it turns into the massive 4". Here's an example: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=7354794&Description=Exhaust+Flex+Tubing
DieselSmoker - no offense taken. I appreciate your feedback - thanks for being honest about what you think.DieselSmoker said:I'm sorry to go against the grain and dont mean personal offense to the poster, but this is the riciest TDI mod I've seen yet. There is absolutely no need for such big piping, what a royal waste of time.
You have to check this out then! I just put on a shark fin antennaDieselSmoker said:I'm sorry to go against the grain and dont mean personal offense to the poster, but this is the riciest TDI mod I've seen yet. There is absolutely no need for such big piping, what a royal waste of time.
devonutopia - "Need" and "Fine" are such funny words, they have such different meanings to different people in different situations.devonutopia said:But 2.25" will be fine for the biggest turbo the 1.9 can handle. I should know as it's currently bolted to my car outside. Not taking anything away from the mod as it's some decent work, but there's little need to go above 2.5" even when going for 300hp.
Just look at what Ed is doing...209hp w/vnt20 and stock exhaust.devonutopia said:...so big power can be had even from close to stock exhaust systems.
Ummm ... not quite "stock exhaust"greengeeker said:Just look at what Ed is doing...209hp w/vnt20 and stock exhaust.
