3.0 TDI Valve ID
JoeM5952
Portland, Or
MkVI Jetta DSG
My coolant was low and while trying to trace if there is a leak, I noticed this valve hanging down and tube rubbing on the belt.
Anyone able to let me know what this is?
I also never saw a leak so if anyone know any common culprits let me know.
TurboABA
Kitchener, ON
That appears to be the exhaust gas recirculation cooler change-over valve.....
Most prominent sources of coolant leaks are under the intake, the in vee.... typically the oil cooler and\or coolant bypass valve.
JoeM5952
Portland, Or
MkVI Jetta DSG
Thank you for the help,the belt rubbed into the hose some as you can see. If I were to undertake a project such as pulling the intake, is there anything else I should do while in there?
JoeM5952
Portland, Or
MkVI Jetta DSG
Thanks again, I've had several Audis but this is my first TDI and for some reason I just have this thought in my head that diesels are hard to work on.
T1MMBOJONES
Milwaukee
2013 CJAA JSW/DSG
modern diesels are pretty complex but so are a lot of gas engines these days. if you owned any turbo gas engines i cannot imagine its much different...hard on the wallet yes but not necessarily harder to work on...that said i havent owned a gas powered vehicle for over 15 years and my girlfriends scion rarely needs anything but general maintenance.
commedeschatons
PNW
2003 ALH Wagon 5mt, 2016 VW Touareg TDI, 2014 Q5 TDI, 2011 335d Msport, 2009 Q7 TDI
Reseal everything :)
Here is a comprehensive list of all the parts you need.
(Vac caps are not required if you are not deleting EGR cooler)
(temp sensor ORINGs are optional). Everything else isn't)
NYHD
Annapolis MD
2013 Beetle and 2014 Touareg
I have a leak in the valley and just ordered the parts. Now M thinking maybe I ought to do a delete while I am in there. I am mot ready to do a DPF delete but does it male sense to delete the EGR cooler now? I guess could do more research but being lazy I thought Id just ask here what my options are. Thamks
