3.0 tdi solenoid injector conversion?
Machineman
ontario canada
2007 RS4 Titanium 3.0TDI & 2013 Touareg TDI & B6 S4 BHW Swap Biturbo
Looking for some insight on a solenoid injector conversion seems like upgraded piezo nozzles are inpossible/expensive
Newer 4cyl cr use solenoids but my edc16 is for piezo anyway to convert it for solenoid ? Or am i stuck with goin standalone management?
hatemi
Finland
Audi A6 4F 3.0TDI
Solenoid is a step in totally wrong direction. In fact I will convert my E46 to Piezos at some point in the future. With solenoids you are limited to 1600bar rail which is pretty lame.
Lähetetty minun LG-H870 laitteesta Tapatalkilla
Macradiators.com
Romania
2.0 CR 360hp
Stay with piezzo, big injectors and 2500-2700 bar rail pressure should do it.
Should consider using meth as fuel as well.
Somebody i know with my big cp3 pump is using the solenoid injectors at 2100-2150bar but injectors are not big enough for your goal.
TDIfreak
Finland
Multivan AHY, Golf CFFB DSG, A6Q 4F 2.7 TDI CANC, 7 meter boat with ALH.
There are Bosch solenoid injectors for at least 2200 bar already from the factory. So it shouldn't be a problem to run them with high rail pressure.
Machineman
ontario canada
Turns out the injectors from 6.7 power stroke are the exact same as stock piezo vw so i think im good to go
TDIfreak
Finland
How many injectors in that Ford?
Bobby Singh
England,Middlesex
Audi 3.0 TDI
Turbo Z
Sweden
Audi A2 mercedes c270
Well I have solenoid injectors about 50% bigger then BMW 550D injectors, take 2200 bars original rail pressure and 8 injects evens / combustion cycle
have duration map as well
Machineman
ontario canada
Me and my brother run a performance diesel truck shop We just did a customer's 6.7 its putting down almost 650hp on stock nozzles with a dual hpfp I will agree these nozzles probly arnt much bigger than 3 l TDI But there are larger ones available As far as making big power goes The risk is always gonna be high I'm not worried about smoke either
Machineman
ontario canada
I've been in contact with the company that makes these so we will see
