3.0 TDI owners...anybody experience issues with the starter?
mrrhtuner
London Ont Canada
2003 Jetta Wagon TDI, 2015 Passat TDI, 2015 Touareg TDI
Hey fella's,
My dad's T2 2010 Touareg recently left my mom stranded and wouldn't start. We had it towed to a local euro shop that determined the starter was at fault.
A used replacement was sourced from quebec and installed.
The touareg starts up great now, no problem.
My main concern is what could have failed in the starter so early? We have about 75,000km on it IIRC.
My dad mentioned that with the cold, it was having a harder and harder time starting. With the used/new one, it fires up great.
Anybody else have starter issues on the 3.0TDI?
Any idea's where it's located exactly? I would have loved to replace it but was told about this after the job was already done.
Dodoma
2002 Jetta White
Starters fail. You find that out by hammering to see if it can crank. If you hear click but the starter does not crank, than the starter is bad. It could be the bushing. But you can get a remanufactures starters easily and they are not expensive. Check with PepBoys.
IFRCFI
Winchester, VA
2013 Touareg TDI Lux
It's a 6-7 year old vehicle, with relatively low mileage. Lots of short, stop/start trips per day? Lots of cold weather starts? Sits outside? Any preheat? Doesn't seem abnormal.
mrrhtuner
London Ont Canada
No issues on mine. Fingers crossed. How long did it take the shop to switch the starter?
Top Gear, a local polish euro shop charged 8 hours but that also included oil change IIRC.
Well I was going by what I've seen with most other cars out there. My dad's T2 touareg sat for a year in a shop, so it's seen about 5 years on the road.
Not many short trips at all, my parent's don't go out driving just to drive. They are conservative. They go out, buy what they need and stay at home.
Sits outside, no pre-heat.
Still seem's pretty abnormal for me. I've requested the old starter back to take it apart and have a look.
RebelTDI
Boston, MA
2016 Audi Q5 TDI, 2016 BMW 535d Xdrive
I'm hoping the starters on models with auto Stop-Start are more robust. My Q5 shuts off at stop lights, which definitely helps with mpgs. If they wear out more quickly, though, that would negate any fuel savings. In some situations I turn it off. I traded in a Jetta Hybrid for the Q5. The hybrid shut off when stopped, of course, but it used the electric motor as the starter.
mjhandy
Kitchener, Ontario
2009 Touareg TDI
8 Hours?? Doesn't that seem kinda high? I know it's not simple but makes it a crazy expensive job.
Let us know if you get back the starter.
NoobyT
N/A
N/A
You don't read about Touareg starters failing very often - they're normally pretty reliable.
But it's an electro-mechanical item - sometimes they just go tits up. I wouldn't waste a moment pulling it apart!
And I certainly wouldn't have fitted a used one with no known history especially if someone took the best part of 8 hours to fit it!
mrrhtuner
London Ont Canada
You know, we lack here a proper euro shop. We have some, but they charge about 95% of what a dealer charges...and the others...well they are the only thing we have.
I agree, 8 hours sounded like an ordeal...but my dad tends to trust his people and he foots the bill :rolleyes:
It won't hurt to play around with it now that we have it home. My dad picked up the old starter last night and I'll pop by in a day or so to snap some pictures and take a look.
deeslman
Newfoundland, Pa.
2005 punchbuggy 2006 jetta
In the shop for a year????
