Not happy with the results, but still enjoy the Q5. It will be interesting to see other post repair milage results. C'est la vie.
I run with a Chipwerke piggy back tuner in. It helps with both powers and efficiency. I also run in manual mode quite a bit and am having luck retraining my transmission to shift at lower rpm’s when fully warm. I am seeing a small uptick in mpg in early spring. Two tanks and 1000 miles my average was 33.7, about .5 higher than pre-fix wintertime average. About 300 miles into this current tank, my on board computer reads 39.2, which normally translates to about 35 mpg.
It is obvious to me how much a Diesel engine likes to run in warmer temperatures. I can’t wait until summer diesel comes, which will be in just a couple weeks here.
Since I drive for efficiency, I would be very aware if the fix had greatly affected that aspect. It hasn’t. I won’t know hard numbers until summer, but it is looking very much like the mpg’s I get will not have deviated from prefix by more than half a mpg, if that much.
Why might others have seen a bigger drop off? The most likely cause would be a lot of cold engine operation. City driving, short haul trips, engine never fully warming. This keeps the engine in warm up mode when it is more affected by the fix programming. Interrupted regens.
Click my fuel link below and you can see my actual results. Final note: i live in a rural area. Few stop signs, fewer lights, lots of driving between 50 and 70 mph. Perfect for high mileage. That is why my numbers are very high comparatively.
