Hi everyone,
I'm new here and hoping to get advice from someone who's been through this before.
I have a 2011 VW Touareg with the 3.0 TDI CRCA engine. The car runs great — no overheating, stable temperature, strong heat from the HVAC, and no external leaks. Coolant level has been stable for months. However, I’m noticing something odd and repeatable:
My suspicion is the EGR cooler — maybe exhaust gases are pushing into the coolant side during load, without actually causing a leak. It seems too clean and consistent to be a head gasket failure, but I’m open to all ideas.
Has anyone experienced air accumulation in the coolant system without coolant loss like this?
Could a hairline crack in the EGR cooler cause this kind of behavior under load?
Any input or similar stories would be much appreciated. Thank you!
- After intensive driving (long highway trip or spirited driving),
- The coolant level in the expansion tank drops by about 200–300 ml,
- After the car cools down overnight, I open the cap — there’s a clear release of air pressure,
- And then the coolant level returns to normal.
- No bubbles in the tank, no loss of coolant over time, no oil contamination.
