wjdell
It seems fine the VIS 100 C did drop from 7.5 to 6.4 -Shearing may be the major reason VW calls for changing this fluid every 40k. i was going to go 50k this run but am having second thoughts. Wear is minimal and this time the improved filter ending in C went in. DSG fluid has many task - HEAT transfer - Pressure - Gear lubricant, to name a few, so I am wondering if pressing it out past 40k is a good idea. Maybe someone who better understand shear and whether the drop 7.5 to 6.4 is a issue will respond.
I can say the fluid and filter were much cleaner this change than the first change. Fluid looked like new, and the filter was still white. The first filter had become very dark.
Link for UOA of DSG figures below
http://forums.tdiclub.com/showthread.php?t=147504 post #2
